Old 04-12-2010, 05:27 PM
Hudo4's Avatar
Hudo4 Hudo4 is offline
Default 4 Runner Suspension Install
It's been a while since I've put in a lift into any rig let alone my 4Runner. It's currently stock but I'm planning on putting in a 2.5" lift. OME881 and 890's. My question is this, will I be able to get it high enough off the floor of my garage to put the new lift on? Will a Hi Lift jack get me off the ground enough to install the coils?
Thanks for the help.
Newbie
Old 04-12-2010, 05:29 PM
depends on how high your jack stands are. Take the wheels off of course.
Old 04-12-2010, 05:36 PM
Hudo4's Avatar
Ow, good point. The ones I have wouldn't be sufficient but I think I could get ones that might.
Old 04-12-2010, 05:40 PM
nakman nakman is online now
I've got a pair of larger ones you could borrow. You can also take my floor jack too.
I've never lifted IFS though but hey I'll help you with the back!
Old 04-12-2010, 05:46 PM
Hudo4's Avatar
Gracias Amigo. I'll have to think on it a bit. Do you remember how tall the large stands you have can go up?
Old 04-12-2010, 05:48 PM
They can make an 80's frame high enough to install a 4" lift? I dunno, they're the 6 ton ones from HF.. so looks like 24" http://www.harborfreightusa.com/usa/...bCategoryName=
Old 04-12-2010, 05:52 PM
Hudo4's Avatar
I'm thinking that might do it. Let me see if I have all the necessary tools for the job. Thanks Nakman
Old 04-12-2010, 06:05 PM
Remember, you don't have to actually lift the truck that high I don't think, at least not in the back....
You get the tires off, frame on jack stands and then support the axle with the floor jack and lower it a bit to aid in getting the springs in...Just don't over extend the brake lines
Take all this with a grain of salt coming from a guy who has only helped install lifts, never done one myself.
Old 04-12-2010, 07:08 PM
Its up to you, but I would HIGHLY recommend getting the front springs installed onto the struts before taking anything off. It can be done with a regular spring compressor, but its HARD. We broke two doing my dad's lift. Take em to a shop (Slee) that has a wall mounted spring compressor. Takes a couple of minutes for them to do it, but its WORTH it.
Also, the front will be difficult to put in. You will REALLY have to pry the lower arm down to get the new coilovers in place. It really helps to have a second, or even a third, person.
Old 04-12-2010, 08:07 PM
JadeRunner's Avatar
Cruise Moab Co-Chairman
I agree with Ike on having someone with the proper press to put the coil-overs together. Installing them on the front is easy. Just use your stock bottle jack between the top of the a-arm and fender well. That will push the assembly down enough to slip the coil-over in place. YotaTech.com has extensive write-ups with pictures on all this.
Scott Yoder KD0DHP
