Old 04-22-2010, 03:58 PM
Ron Helmuth's Avatar
Ron Helmuth Ron Helmuth is offline
Yes the rear springs are a piece of cake but if you are doing the shocks also read up and be sure you are prepared for those.
I second Axle Ike's posting on having the fronts pre-built so to speak. A wall mounted compression device is the cats meow for that setup...
I am running 881s and 890s myself and that is a good all around choice for lift without going massive on the rake and still able to fit in a standard garage. I also have some large wood blocks that assist with the reach necessary for jack support.
The Hi-Lift fits nicely in the receiver hitch out back but get it supported quickly-I can't recommend leaving the vehicle so precariously balanced for any real length of time.
99 4Runner SR5 V6 4x4 5 speed
LT265/75/16 Michelins at present
Fact. rear locker, OME 881f/890r springs/Nitro shocks ARB/Clear lenses/LTD. woodgrain/Sonar tails/body lift
http://www.facebook.com/album.php?ai...5&l=5795132731
