Old 04-15-2010, 06:18 PM
OK, thats what I thought, so even if I go gasless for a while I won't be suffering any worse than I was arc welding.
Old 04-15-2010, 06:20 PM
I'm sensing that there should be a restocking fee evaluated in barley pop.
I AGREE FULLY! Nakman, tell me your brand and a case of it will be provided at CM, plus anytime you need welding you just come on by.
Thanks
Old 04-15-2010, 08:06 PM
So, if I"m following this thread correctly; Nakman's new welder is not heading north from my garage but it heading south to become Randy's old welder...
  #24
Old 04-15-2010, 08:07 PM
Yes
  #25
Old 04-15-2010, 08:46 PM
Beater's Avatar
Beater Beater is offline
sorry tim....
john (johnny) henley
  #26
Old 04-15-2010, 09:58 PM
I have not tried it yet but can I hook up my powertank to run CO2? Special regulator required? I've been running the standard 25/75 mix with my Miller 211 so far.
Randy, what's stopping you from getting a bottle right away?
  #27
Old 04-15-2010, 10:04 PM
Nothing, I just wanted to make sure it was really worth it. I'm so used to arc welding with stick I thought welding with flux core wire might be about the same.
  #28
Old 04-15-2010, 10:36 PM
got it makes sense. Once you get a bottle I bet you never go without though.
  #29
Old 04-16-2010, 08:30 AM
You're probably right. Another question: I got the plasma cutter hooked up and functioning last night. I know when I've used oxy/acet torches in the past to cut you angle the torch slightly into the direction of cut and "push" the puddle forward. Do you do it the same way with the plasma, or do you "drag" the puddle or maybe it doesn't make any difference?
  #30
Old 04-16-2010, 08:40 AM
Beater's Avatar
I have a love hate relationship with my plasma cutter. Unless you leave your plasma hooked up all the time, I find it easier to just whip out the oxy/fuel and be done with it. That aside, it depends on amperage/thickness.
On thick stuff, I undercut slightly. On thin, I stay vertical. I always use a drag or pull motion with my arm, never pushing. I find that you get less variations. You can usually drag your tip at less than 30a anyway. you should have little to NO puddle with plasma. If your building a puddle on plasma, your moving too slow or not using the right amperage for that thickness
Big tip: If you have the option, get the "art metal" or "fine" tip, whatever the mfg calls yours. the small kerf makes ALL the difference imho.
