Old 04-15-2010, 08:18 AM
Default Techniques for Removing Sliders
Looking under my truck recently I think I'm going to have to remove the sliders this summer. My rocker panels and pinch welds are creased and bent up and the paint is flaking off to bare metal when the sliders have impacted. Another winter will not be kind to the paint I'm afraid.
So what is the best method for removing welded-to-the-frame sliders? Bill made scab plates that he welded to my frame, to which is attached the slider legs with corner bracing. My thinking is that it's best to leave the scab plates welded to the frame, cut the legs and grind the welds flush to the scab plates. That way if sliders ever get put back on they would be welded to those plates and not subject the frame to another weld.
Old 04-15-2010, 09:04 AM
RockRunner's Avatar
You can stop by my house this weekend and use the plasma cutter and then grind clean. Or if it can not reach an area we have the sawzall too. LMK I will be working all weekend loooonnngggg.
Thanks T aka Tom KR0MPS
TLCA #6136
Old 04-15-2010, 09:23 AM
What are you building that is going to take all weekend?
Old 04-15-2010, 06:18 PM
Dave could you cut the arms so you leave a little stub coming off the scab plates? Then when you reattach, could you use a larger piece of square tubing as a coupler? And for that matter, heck put bolts through both ends of the coupler and stubs so you'd have bolt-on sliders?
Old 04-15-2010, 06:51 PM
As soon as I read the word 'stub' the light bulb went off. Then I found myself saying 'duh' when I read that last sentence. Duh. That's EXACTLY why I posted what might seem like an obvious question, for that 'ah ha' moment. If I do it carefully I might even be able to salvage these, eh.
Old 04-16-2010, 09:26 AM
Right on. Something like this, right?
Old 04-16-2010, 09:53 AM
I always do the opposite nak, sleeve on the inside to keep it incognito.
Old 04-16-2010, 09:57 AM
Yeah probably depends on the availability of tubing too, right? Do you re-weld yours, or through bolt it?
Old 04-16-2010, 10:26 AM
when I need to sleeve things I drill a couple holes in the outer tubing and plug weld.
Old 04-16-2010, 11:00 AM
I was thinking the same thing. Cut the outrigger half way and then sleeve it inside or outside, and you could bolt, weld or whatever. I think your biggest issue at that point will be a tight fitting sleeve setup.
Sorry to hear about the damage Dave. Is there anyway to avoid it in the future when you bolt them back on?
