Old 04-20-2010, 01:36 PM
they are just in the head. When you pull that head off you'll be able to stare at the bottom peice of the broken off one. I wonder how cleanly it broke off... MAYBE you can weld a nut to the side that is in the chamber and screw it out that way...
Once its off and on the bench you should be able to use a large seat extractor (buy cheap ones at Home Depot or Lowes for plumbing) and hopefully twist it back out. You might have to drill it to make a clean bore for the extractor to grab. A good machine shop can do it for you too probably cheaper than the extractor would cost. Hopefully the treads are still in good shape or you will need to Heli-coil them. Again a machine shop can do both without wasted time and other possible damage.
Thanks dudes.
Thats what I thought, but I wanted to make sure.
I'm going to evaluate the head once its off. I have a good set of extractors that I'll use if it looks possible. If not, I'll be going to a shop with it.
Just left a message with Jerry for an order of a new timing belt, new head gasket, new intake manifold gaskets, and a water pump.
For now, I'm leaving the other head off the list. I'll see what this looks like first.
Old 04-20-2010, 01:48 PM
powderpig's Avatar
Do you need a true bar to check flatness? I have a couple, small and large.
You have my number if you need one.
Old 04-20-2010, 03:11 PM
Yes I do. I didn't even know to check that. I'll ring you later, but the head isn't off yet, so I won't need it ASAP anyway.
Cheers!
  #24
Old 04-20-2010, 04:20 PM
Robbie, UB, et al:
Any trade secrets to getting the head off? FSM says to pry it with a screw driver, which I don't like at all, as there is too much potential for damage to the surface. Hanes says to place a block of wood against the side of the head, and tap it off with a hammer.
What do you all use?
  #25
Old 04-20-2010, 04:55 PM
Robbie, UB, et al:
Put two head bolts in loosely. Grab some wooden dowels or broom handles or ???? and slip them in to 2 intake holes and gently but with a sharp movement pop the head loose. Make sure its still on the deck alignment dowels, remove the loose head bolts and lift the head out.
  #26
Old 04-21-2010, 12:05 AM
Thought I might get the head off tonight, but no such luck.
Stuck on the exhaust manifold, but MAN I love air tools. Getting all of the pulley bolts off= super easy with an impact.
I thought I could MAYBE get enough play in the manifold to not have to remove the x-over pipe, but I think its going to have to come off, which SUCKS.
I also didn't have very much time tonight, as I had grilling duties, and had to hit Costco on the way home.
Anyway, progress:
Removed the AC bracket, timing belt tensioner, top idler pulley, the timing belt, and the LH cam pulley.
Any ideas on quick ways to get these monstrosities out?
  #27
Old 04-21-2010, 06:44 AM
powderpig's Avatar
Use a internal torx socket(8) I believe to remove the studs. It usually only takes a few minutes to remove and makes my life easier when I do this type of work.
  #28
Old 04-21-2010, 11:22 AM
Ah! Genious! I was wondering how to get those out! Much easier that way.
  #29
Old 04-21-2010, 11:25 AM
Or plasma!
  #30
Old 04-21-2010, 01:19 PM
Originally Posted by Rezarf View Post
Or plasma!
LOL. True, but I think my brother isn't looking to do headers at this time, as this cost is quite a bit higher than the original spark plug job anyway! LOL.
