Old 04-19-2010, 07:10 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Default Air Conditioning Not Cold
My air conditioning is not cold anymore. Can anyone recommend where I should have it looked at, of anything else I should check first?
Compressor works, belt is still there, fuse is good, compressor kicks in.
Thx!
Old 04-19-2010, 07:59 PM
Dr. Schlegs's Avatar
Freon leaked out? O-rings dried up and Freon escaped.
TLCA#5366
Old 04-19-2010, 08:00 PM
this close to moab just throw some more freon in it...
I mean, I'm sure it leaked somewhere, but if the compressor still cuts on it still has some freon in it.. It'll leak down again, but deal with it after the trip..
Old 04-19-2010, 08:02 PM
74fj40's Avatar
74fj40 74fj40 is offline
If the r134a leaked out the compressor would definitely not be kicking on as the low pressure sensor the not allow it to.
Are you 100% that the compressor clutch is engaging?
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
Old 04-19-2010, 08:13 PM
Inukshuk's Avatar
How?
Its a 1993 and I believe R-12. Not 100% sure, but engine revs up and nothing sounds or acts out of the ordinary.
Old 04-19-2010, 08:27 PM
74fj40's Avatar
Hmm most shops are still able to put R12 in your system if that is the route you choose to go, but R12 is expensive and not something I would want to do twice.
1972 Toyota FJ40
[/font]
Old 04-19-2010, 09:02 PM
ttubb's Avatar
ttubb ttubb is offline
Default Freon
There should be a label near the top of the radiator that states R12 or R134.
KA7TLT - TLCA 13015
Old 04-19-2010, 09:04 PM
you can go to Autozone and get the fill tube thinggie and a can of freon for pretty cheap.. it comes in a package together. then just hook it up and let it suck it in as it runs.
I know people say it's a no no, but i've mixed 134-a and r 12 and it's been fine. Even put in 134-a on r12 systems without doing the o-ring changes and it has done OK.
The "conversion kits" they sell are just basically o-ring kits and adapters so you can hook up the 134-a fill tube to the r-12 port on the truck
I know that on several cars i've worked on the freon was "low" enough to not cool, but still had enough pressure to kick the low pressure switch on. Usually it just takes a half a can or so to do that.
Look and see if it takes r-12 or 134-a and then go from there. If it takes r-12, you'll need the "conversion kit" and chances are that the kit from autozone will have what you need. just walk in there and tell them what's up and they'll actually be able to help you... I think...
Old 04-19-2010, 10:07 PM
Inukshuk's Avatar
Default label says R-12
Nice - label says R-12
Old 04-20-2010, 01:53 AM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
if its r-12 please dont convert it to r134a.. r134a is crap compared to r12.. there is a enviromentally OK verson of r12 that dose not harm the enviroment. and will not harm your system like r134a will. 134a in a 12 system will runin you system and damage componets.. i dont want to get into it.. just go to napa and buy the stuff called "freeze 12" its a epa aproved version of r12..
r12 is colder than r134a
and freeze 12 is colder than r12 ive used it on several cars and it is absoltuatlly wonderfull stuff.. and its only a cupple bucks a can.. basically the same price as r134a use the 134a conversion adaptors so you have the quick disconects (easier to add the freeze 12) because you dont have to find r12 hoses..
granted someone will probly say "no your wrong" well thats because r134a is very cold when used in a r134a designed system.. but NOT in a r12 system..
TLCA # 20314
Step by Step Bed Bob
