Old 04-25-2010, 11:11 AM
Default How not to do shop air lines...
Black pipe and Teflon tape. This weekend's project is redoing all the plumbing from scratch and it's taking forever...
Old 04-25-2010, 11:37 AM
turn the air up...the black abs will go away
Old 04-25-2010, 11:40 AM
ABS??? I'm not that dumb. I used black iron pipe. It just sucks almost as bad as Teflon tape for leaks.
Old 04-26-2010, 08:11 AM
High pressure plastic lines. Seals nicely.
KDØRCH
Old 04-26-2010, 08:18 AM
Ive seen that stuff and it looks pretty neat. Only reason I didn't go with it is because I need a bunch of drops for stationary machines and I didn't know anyplace to get odds and ends to expand the system. So I ended up sweating 1/2 inch copper water pipe instead.
Old 04-26-2010, 10:05 AM
Always use pipe dope on metal lines and Teflon tape on plastic!
KØUBN
Old 04-26-2010, 11:01 AM
jettaglxdriver's Avatar
jettaglxdriver jettaglxdriver is offline
Yeah pipe tape is to lubricate the plastic fittings enough to get them assembled without them breaking and because it won't react with the plastics like some dopes will. Metal fittings get dope. Tape will seal if you work with it but it's easier to use dope.
Thank you for calling. Press1" for English, press "2" to disconnect until you have learned to speak English
TLCA# 19853
1982 FJ60
1991 Toyota Paseo 38MPG baby
1995 JettaGLX VR6turbo project car
