Old 05-03-2010, 08:00 PM
Default Another battery thread....
So after winning the National Luna dual battery set up at the raffle I need another battery to complete the system. My plan is to mount the 2nd battery under the truck using the Metal Tech battery tray that bolts up to my sliders. I'll move my accessories like the fridge over to the 2nd battery. I currently have a group 31 blue top Optima. So I could replace my starting battery or get a larger battery to run the accessories.
New starting battery: Die ard Platinum group 65, $200
or
New accessory battery: Deka group 31, $183 or $219 depending on model.
I have a local Deka retailer(Hensley) in Durango so that is easy Or the nearest Sears is an hour away. The biggest advantage to the Die Hard I see is warranty, 4 years full and 100 month prorated. Where the Deka is only 18 month full and 18 month prorated. Plus its probably easier to find a Sears when traveling than a Deka dealer if it fails while on vacation.
Any other batteries I should consider? I have NAPA, Autozone, O'Reilly in Durango. to shop other options.
Old 05-03-2010, 08:24 PM
Snowrun's Avatar
Snowrun Snowrun is offline
I like the Diehards from a capacity standpoint, however the issue I ran into is the battery terminals are so close to the edge of the battery that there is a risk of shorting via the tie down. Treeroot fabricated a custom one for me and there are no issues now.
One other thing I like about the Diehards is almost anywhere you go around the country there is a Sears store for replacements if needed.
'94 FZJ-80 Locked
'99 LX 470
TLCA#21035
My Cruiser videos on Youtube
Old 05-03-2010, 10:47 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Duralast Cromwell autozone were rated best/strongest battery nationwide in a 3 party test about 3 years ago. I'm sure nothing else has changed. I've used them and love them. Just buy the gold series. They also have the best warrenty.
TLCA # 20314
Step by Step Bed Bob
Old 05-03-2010, 11:32 PM
First of all you suck on winning the National Luna system!!
As for batteries, it seems we are having a bit of "hit and miss" success with the Dekas (see Romer's thread) so maybe the Die Hard is the way to go...
Let me know what you think of the National Luna system once you get it set up...I was talking to Paul about it but based on what I've read I'm thinking for my application with the winch and all it may not be the way to go
Old 05-03-2010, 11:46 PM
what about your winch?
I originally planned to copy Marco's dual battery set up but after winning this it looks like I'll be running the National Luna. Unless I sell it? Romer's Deka's were blems so its hard for me to base a decision on those. Others seem to be happy. I could go with the Die Hard marine group 31 but that one is money at $250
First I need to get the Metal Tech tray and make sure there is room for a group 31 there. It was designed around a smaller group 34 I think? But I much prefer to keep the COG low with it mounted down there.
Old 05-04-2010, 12:21 AM
Corbet you got this kit right? http://www.equipt1.com/h/component/p...art/Itemid,31/
so sweet...
Old 05-04-2010, 12:54 AM
treerootCO's Avatar
Event Coordinator
I went this route with the National Luna kit because of the winch. The kit says, do not use anything that comes in this kit if you plan on using a winch.
I have the Deka batteries and couldn't be happier.
140 +95 + 70 +50
Pac PAC500 500/700 Amp Power Relay/Battery Weatherproof Isolator PAC500 606523108041
EQUIPT Expedition Outfitters - National Luna Intelligent Solenoid
EQUIPT Expedition Outfitters - National Luna Dual Battery Controller (with dual audible ala
Genuinedealz > Marine Electrical Supply - Boat and Marine Electrical Connectors, Tubing
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 05-04-2010, 12:56 AM
From what I've read and in talking to Paul, the cabling that comes with the kit is a little on the small side for use with winching operations...I think the instructions even mention that as well. Paul's suggestion was to buy the piece parts separate if it was a concern because a lot of the cost of the kit is rolled up in the cabling anyway.
That said, if I won that kit I'd be running it for sure even if I did have to spend some to upgrade the cabling
Old 05-04-2010, 07:33 AM
so sweet...
Yes, that's the one
140 +95 + 70 +50
Mike, thanks for the links. So you basically just replaced the solenoid and wire with heavier duty stuff. After reading the install instructions that was what I concluded it needed as well. Did you do a write up when did the install? Edit, found it http://www.risingsun4x4club.org/foru...t=luna&page=64 But mike why did you link this one but use the Wrangler Power unit in your build?
Search for Marco's dual battery write-up. I think you'll copy his if starting from scratch.
Old 05-08-2010, 08:04 AM
If you have a winch, you'll need to upgrade all that cabling.
I installed the National Luna kit in my 60 (no winch) and I love it. Works great and I really like the voltage readouts and controller in the cab. I recently ran my engel 45 for 5 days without starting the rig. It lowere my optima yellow top aux battery down to about 11.8 volts, then auto switched to the other battery (after 4 days). Started right up when I went to leave camp.
Here's the link to my national luna kit install
