Old 05-08-2010, 08:47 PM
Default FJ40 Engine and 4 Speed
Well over a year ago I started collecting parts to put a 4 speed transmission into my FJ40. I have an F.5 engine with new gaskets and seals, a ceramic coated 6 into 1 header, a new diaphragm clutch, 4 speed transmission, 4 speed t-case and 3.70 thirds ready to go in. After that, a new exhaust will be done. This is an very interesting learning experience and the largest project I've take on.
I'll add pictures and notes, observations to this thread and post up my progress along the way. Here is the new (to me) engine.
As of this evening, the 3 speed t-case, transmission, transmission hump have been removed. Considering that the seats, heater and gas tank all need to be moved somewhat, I'm pretty pleased that I have only one broken bolt head.
Tomorrow is Mothers Day so I won't get very much work done. Perhaps I'll progress some during the evenings this week. It is nice to finally be into this project and I'm looking forward to the end result.
Old 05-08-2010, 10:40 PM
Well over a year ago I started collecting parts to put a speed transmission into my FJ40.
I wouldn't count on it giving you much extra speed!
...Cool project Ricardo! Why are you going 3.7 gears? And why didn't you pull the whole shebang out all in one shot?
Old 05-09-2010, 08:44 AM
I'll be watching this thread to find out what you learn. Someday I'd like to do the 4 speed swap as well.
Old 05-09-2010, 09:34 AM
'bout time
Looking forward to watching your progress. Too bad you live way down there on the south side....
Old 05-09-2010, 10:10 AM
While you have easy access I would make a simple fluid heat riser for the bottom of the intake. Very simple to do task and you will be very glad you did next winter!
Old 05-09-2010, 10:56 AM
kvanoort's Avatar
kvanoort kvanoort is offline
I see you've upgraded to an electronic ignition as well. Nice work!
Kent Van Oort
Lafayette, CO
1972 FJ40 Current Project, 1978 FJ40 Sold Project, 1975 FJ40 High School Cruiser
TLCA #17904
Old 05-10-2010, 10:16 AM
theboomboom's Avatar
Matt-
We're installing the 3.70 thirds in an attempt to lower the highway revs and hopefully make it a more livable 65 mph truck. Also, we're removing the transmission and t-case separately because of the way the truck is pulled into the garage. In order to pull everything out on the hoist, the truck would have to be pulled out to the downhill sloping driveway without a good way of getting it back in the garage.
Rick Maestas
KD0CGE
1997 T100 4x4
Old 05-10-2010, 10:30 AM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Just push it with your other car ! Place a old tire or wood betweer the bumpers. And slowlly push ! It would make the whole motor process much more enjoyable.
TLCA # 20314
Step by Step Bed Bob
Old 05-10-2010, 11:01 AM
I've been running an electronic ignition (78 small cap dizzy and 60 series coil/ignitor) since last summer. I'm pretty excited to have be making the move to the 60 series dizzy. My carb still does not have the ported vacuum but there will be time to take care of that this summer.
My fab skills and equipment are not sufficient at this stage, so I'll have to go with the man-a-fre riser. This will likely be something that I add on after getting it all up and running.
Originally Posted by theboomboom View Post
Matt-
Of course, the 3.70 thirds may not work out very well when driving in the mountains.
The access is also gets complicated by the garage door itself. I've been giving this all some more thought and will try to put everything in as a single unit. If we position the truck at an angle coming into the garage, we should have enough room to put everything in.
Old 05-10-2010, 01:01 PM
You need a square 3" x 4" 1/4" steel plate, a 3/8" bit, 7/16" bit, 3/8" pipe tap and a couple fittings found at Home Depot or Lowes.......thats beyond your capabilities?
