Old 05-09-2010, 09:17 AM
kvanoort's Avatar
kvanoort kvanoort is offline
Default Front Disc Changeover
I need to rebuild my front diff on my '72 40 and would like to upgrade to disc brakes. Is it possible to take a '77 front diff and simply switch out the drum to disc parts from the knuckles out?
Kent Van Oort
Lafayette, CO
1972 FJ40 Current Project, 1978 FJ40 Sold Project, 1975 FJ40 High School Cruiser
TLCA #17904
Old 05-09-2010, 09:26 AM
Yes Kent, just swap everything from the knuckles out. What all do you have from the 77?
If it is the whole axle (and the gearing is appropriate) you might want to consider prepping the 77 axle and then just swapping the axles.
Old 05-09-2010, 10:01 AM
kvanoort's Avatar
I picked up a complete front axle from a '77 40.
Kent Van Oort
Lafayette, CO
TLCA #17904
Old 05-09-2010, 10:06 AM
By knuckles out I assume you mean from the knuckle balls out. The knuckle has the ears for the calipers to bolt to. I agree with Ricardo that it's easier to just swap the whole axle. You will need to change the brake lines as the 77's has two brake lines to the frame while the 72 has the preferred single line near the middle coming up. The drive flanges will probably be different pattern too. Both should be 4.11's if they have the stock gears. Depending on production date the 77 might even have the fine spline pinion in it.
Old 05-09-2010, 10:51 AM
kvanoort's Avatar
I guess I'll just start digging into the '77 axle and start cleaning things up while evaluating what I have as I go. Thanks for sharing your knowledge...
Kent Van Oort
Lafayette, CO
TLCA #17904
Old 05-10-2010, 09:09 PM
kvanoort's Avatar
Found this on SOR's website. Has anyone ever done one of these?
Front Disc Brake Change Over Kit-
USED-Fits 7/70-9/75 FJ40 & FJ55-USED parts have been thoroughly inspected and are in good condition-Comes with from the knuckles out, used hubs, used spindles, used knuckles, used calipers,used disc brake pads, used outer birfield axles, new rotors, & a caliper repair kit-Does NOT come with #080-35B seal (qty 2), #080-59 seal (qty 2), #080-40C shim & gasket set (qty 1), #080-04B lock tabs (qty 2), and #200-12B hub socket, order separately-Specter recommends purchasing #014-01D disc brake master cylinder, & #086-60A proportioning valve-If complete new bearings are desired, see #084-101-For Rear Disc Brake Kit see page 292. recommend new disc brake pads see #084-03.-No return on USED Parts - Club SOR Price is $ 678.30
Kent Van Oort
Lafayette, CO
TLCA #17904
Old 05-10-2010, 09:40 PM
Thats just all of the used 79 & newer mini truck stuff that you need to convert a cruiser to disc brakes plus new rotors. Personally, I would go down to YodaJim's & buy everything you need there. You can buy a complete disc brake equipped front end for $250 so you end up with an extra diff, housing, axles,etc you can sell and you don't have to pay freight. You can still buy new vented style rotors for $30 each.
Old 08-15-2010, 09:38 PM
kvanoort's Avatar
Default Hub Nut Size
Started tearing into the original '72 front axle this weekend and have everything off down to the knuckle. I also began digging into the '77 disc brake axle and ran into a snag. Does anyone know what size the hub nut is on the '77 axle? Is it 54mm? Thanks.
Kent Van Oort
Lafayette, CO
TLCA #17904
Old 08-15-2010, 09:46 PM
Yes, it should be a 54mm. The drum brake axles are 52mm.
Old 08-15-2010, 10:05 PM
kvanoort's Avatar
Time for a trip to Tool King.
Kent Van Oort
Lafayette, CO
TLCA #17904
