Old 05-12-2010, 02:00 PM
treerootCO's Avatar
Event Coordinator
Default Warn 9.5xp wiring schematic needed
I am in need of a Warn 9.5xp wiring schematic. Emailed Warn and no response. I found the service manual for the 9000 but that is the older style solenoid box. I have power to all but the ground in the remote connection and should only have one. Figured I hooked up red to red when it was supposed to be white or something.
Here are the 3wire and 5wire schematics for the X0000 series winches:
Wiring_Large_Frame_3_Wire.pdf
Wiring_Large_Frame_5_Wire.pdf
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 05-12-2010, 03:49 PM
There is one in the manual, pg. 6 - Looks a little different that what you show above...
http://www.warn.com/truck/winches/im...0/68424-C4.pdf
If that doesn't work, try one of these email addresses (or all 3 )
Wright, Todd [WrightT@Warn.com]
Hall, Aaron [HallA@Warn.com]
Kadwell, Rich [KadwellR@Warn.com]
These are email addys and names of folks at Warn that have helped me in the past, with Todd being the most helpful (and most recent) contact
Old 05-14-2010, 11:16 AM
treerootCO's Avatar
Event Coordinator
Here is the .pdf Warn sent for all to enjoy. Thank you Mr. McEwen.
www.root45.com
TLCA #14133
