Notices
Old 05-12-2010, 07:04 PM
RockRunner's Avatar
Nice rig, now build it and let's go wheeling.
Thanks T aka Tom KR0MPS
TLCA #6136
Old 05-12-2010, 08:29 PM
I like the rework of the bed on this one.
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Originally Posted by Beater View Post
I see it's already marking it's territory.
actually thats water from the melting snow eariler... the only leak is what apears to be a pissing valve cover gasket.. caused from a cloged pcv valve..
not driping bad.. mabey on drip every 30 min give or take
Originally Posted by MountainGoat View Post
That is a thing of beauty. Did you check the frame for cracks right behind the front spring mounts?
not for cracks.. but i did check for rust.. and not a single lick of rust on the frame what so ever.. i was trully shocked when i saw that..
Got tube?
yes i do.. but im going to build it first so im ready for moab next year. then ill truggy the rear and cut the frame off at the cab.
Hey Tim, I have a nice set of Toyota chrome steel wheels with a mixed set of 33" tires on them with about the same tread yours have. I'm willing to donate those to your project to get some bling on it right away. You just need to arrange to get them from Justin at Redline, they're out at his place.
Who else has stuff to donate? C'Mon RS'ers, check your junk stash to see what you can contribute so Tim can get this thing built and wheelin' as quick as possible.
got any pics ? im already getting timmbuck2's used 35" on brand new black rims..
as for plans.. just installing all of randy used suspention, then using the spare t-case i have sitting on a shelf to make a double'er.. and installing 4.7 gears (should i install the 4.7 in the front case or rear ? ) i also plan on doing the t-case ebrake cross member from frontrange... then upgrading the front brakes to 60 or 80 (forgot which was a direct fit) and also upgrading to rear disk brakes.. self made chromolly front bumper with 8000lb winch with synthitc line. self made DOM sliders, and self made Chromolly rear w/ class 3 tow hitch (might go 2"x4" steel like my taco)clean up the body and single stage cote the truck.. dont care if the body looks like crap because ill be truggy'd in the rear.. i might bob the bed if rust allows.. tint the window's, (im blind ) Ham, Cb
this list in not in order.. its just as i rememberd everything.. b4 i do most of this list im going to finsh the stupid maintence.. the front axle needs totle rebuild.
I forgot to add 5.29's , lockers, and possibly even a got propane conversion With 2 tanks
TLCA # 20314
Step by Step Bed Bob
Old 05-12-2010, 08:43 PM
sweet! 35's and a 22r. I'll see you in the right lane with hazards
I dunno about all these mods.. sliders and tires and your good to go!
Old 05-12-2010, 08:47 PM
Rear case only, if you do the front case the torque will grenade the back case.
Old 05-12-2010, 09:50 PM
TIMZTOY's Avatar
Thanks
TLCA # 20314
Old 05-12-2010, 09:54 PM
TIMZTOY's Avatar
This is just the major list overall view. I'd like to get it all done b4 CM11 but don't know.and with only a 22r that's why I'd like to do a doubler. And I already have a spare t-case
TLCA # 20314
Old 05-12-2010, 10:06 PM
So Perry passed on all Randy's stuff then?
Old 05-12-2010, 10:10 PM
J Kimmel J Kimmel is offline
you can mod that carb to work in LOTS of places
I ran mine very similar to its current state with a carb for quite some time, only gave me trouble on big inclines, but still made them all.
good trade
Old 05-12-2010, 10:59 PM
RLMS's Avatar
RLMS RLMS is offline
I have an ecu, harness, and manifolds, intake for an 86-87 FYI 22re
Cheap!
Pm me if you have any interest Tim
Justin
New> FJC rear lower link skids <New
