Old 05-13-2010, 07:51 PM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
Default What kind of butane/propane...
Does this thing take??? I bought this dual burner camping stove at a garage sale for $2. I thought I could clean it up and get some use out of it, but I can't figure out what type of fuel cannister it takes? Any suggestions? Maybe all of us are too young to know what this is?!!!
I think it's butane, but it needs to be very narrow and screw onto the attachment in the photo.
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
Old 05-14-2010, 01:20 AM
Given how old that thing works, I would have guessed the liquid coleman fuel (whatever that stuff is) that the old (like back in the 80s to early 90s?) use. But AFAIK the old stoves didn't have fuel canisters that screwed on...You slip the tube into the burner lead, pressurize the tank, and go from there.
Any info on the stove as to who made it?
Old 05-14-2010, 06:18 AM
With the fuel line being heated by the burner, I'd vote for liquid gasoline as well.
Old 05-14-2010, 07:19 AM
LARGEONE's Avatar
Maybe?
So, does the fuel canister have the pump/pressure primer on it? Because this thing has two valves that open like you would have for air gas. They can control how much gas is getting to the burners?
The label on the grill says "SPORTSMAN" out of St. Louis, MO.
Paul
KE0OLZ
Old 05-14-2010, 10:57 AM
Seldom Seen's Avatar
Originally Posted by LARGEONE View Post
Does this thing take??? Attachment 18875
Looks like it used, the now obsolete, Gerry/Hank Roberts type of butane canisters. The needle pierced a rubber stopper in the top of the can and there usu was an adapter, that screwed on the threads, that held the canister in place 'cuz the can wasn't threaded.
Old 05-14-2010, 11:58 AM
def looks like a hank roberts fit like brian posted. they quite making cartridges a while ago. I think you can use an optimus cartridge or something like that. Is it an instalite stove?
you probably need to peruse http://www.spiritburner.com/fusion/index.php
Old 05-14-2010, 12:19 PM
We have a winner
Scroll to bottom
Old 05-14-2010, 02:33 PM
LARGEONE's Avatar
You guys are incredible!!!
Looks like I might have overpaid by about $2.00 for this thing!!!
Paul
KE0OLZ
Old 05-14-2010, 02:50 PM
Eh...For another $4 you can probably find a couple old school coleman stoves that use white fuel and fab up a way to use the tanks and tubing from those
Old 05-14-2010, 03:03 PM
this was like a scavenger hunt.... nice
