Old 05-15-2010, 07:57 PM
Default project emissions 2010
well, the sniffer wasnt' too bad, but i did fail inspection. apparently arvada now realizes that there are supposed to be two cats under an 80
i've had the new cat and a new muffler, along with plans to go up and over the frame for a while...guess they forced my hand. so, project emissions begins. not sure i'm going to be able to make the bend with flex at the first cat. hope so, cause i got no way to bend up tube.
hopefully now, i'll be able to get the new slider mounted up too. we shall see. with the exhaust out, i'm working on cutting off the old slider mounts.
Old 05-15-2010, 09:12 PM
Buy some mandrel bends and weld up your system!
Old 05-15-2010, 09:16 PM
nattybumppo's Avatar
They told me that at Arvada too, but I argued them off their position. I did have to replace the one cat I did have though for it to pass though. This was on my Audi which I have since sold.
Sascha Steinway TLCA # 20217
2013 F-150 "Black Ops"
Old 05-15-2010, 09:51 PM
Bikeman Bikeman is offline
I am not looking forward to this in the fall when my tags are due. I was at A&A Muffler on Thursday having my muffler rewelded to clear the rear CV when I asked Scott what 2 cats would cost in a whole new system from the muffler forward, $600. I may just register the damn thing at my mom's in Prescott if it fails after the work.
Mike
2001 Honda XR400 with goodies
Old 05-16-2010, 02:31 PM
easier said than found. used to be able to find exhaust kit stuff everywhere, now not so easy. need to get it done today cause next weekend is the last weekend i can get it through..i'm gone the weekend after that and if i have to pay the extra $25 bucks for being late, i may just have to go kick ritter in the nads.
everything was looking pretty good until i realized i just welded the old cat on upside down also going to have to actually weld the new cat to the head pipe...i was hoping i would be able to clamp it so it could be easily removed (for replacement, of course) crap!
Old 05-16-2010, 04:56 PM
Weld header flanges on the pipe and cat! It is amazing coincidence that my spun metallic substrate high flow 3" cat fit's perfectly in the same position and my emission compliant dual cat set up fits! Also fortunate is the fact that my spun high flown passes roadside emissions and actually surpasses the original specs of my vehicle. It is unfortunate that "Get Rid of Ridder" new standards require the highly restrictive-cut the fuel mileage to 5 MPG E-comp dual setup. I run a metallic substrate cat because the SC will melt the precious metal cats!
Old 05-16-2010, 07:32 PM
Weld header flanges on the pipe and cat! !
wanted to do that, but also, easier said than found. i used to see them in summit all the time and i can't even find the cheap ones on their website, just the $90/pr ball style. i wish supershops was still around.
this is still just a "temporary" thing. i will have a normal exhaust sometime, but right now, all my money for the next couple of years is going towards a shed and siding. also would really like a different 80...tired of the rust and the p.o. electrical mods.
Old 05-16-2010, 07:57 PM
Any exhaust shop will have both the flanges and possibly some mandrel bent pre-bends.
http://www.summitracing.com/parts/SUM-G4760/
http://www.summitracing.com/parts/HED-21105/
Old 05-16-2010, 08:08 PM
son of a.... i was searching for "flanges"...
got it "done". a couple small exhaust leaks where i welded, mainly cause i can't get to the top of the pipes to get them. it will most likely make a bit of a rattle, cause it's way too close to the frame to not hit it. hopefully that will motivate me to fix it sooner i was two clamps short, so i'll get those tomorrow.
also got 3 of the frame braces for the new slider welded on. got to make the fourth. the p.o. didn't put anything on to distribute the impact and it's kind of hard to see in photos, but your frame will bend.
Old 11-24-2012, 10:42 AM
w8ell, onto project emissions 2012. was due in may and failed. gas cap and nox (you have to have the cap on the vehicle, not in the vehicle ).
results in may, running 2010 exhaust and 2 bottles of heet in a 1/2 tank fuel
hc .8368/2.0
co 15.8675/20.0
co2 586.6560
nox 4.7948/4.0
got home and the cats tested with only 20 degrees difference in to out. hated old exhaust anyways, so saved up for new exhaust
finally today, took it down again. new exhaust w/ new cats, big bottle of rubbing alcohol in 1/2 tank fuel, new fuel cap ON the vehicle
hc 1.0184/2.0
co 10.8315/20.0
co2 765.2759
nox 3.8012/4.0
passed. i do not have to deal with ritters b.s. for two more years (oh, except the $100 extra that my plates will cost since i'm seven months late ). yeah
