Old 06-17-2010, 02:50 PM
Mendocino's Avatar
That is exactly what I want to put on the 40. If everything works and is there it's a good deal. The timing is not right for me however.
Jeff
Old 06-17-2010, 04:02 PM
These antennas typically go for about $300 new, so $225 is a decent little savings.
Old 06-24-2010, 01:05 PM
Icom IC-2800H Dual Band Near Mint Cond. - $400 (Parker)
Cool radio, prolly about $700 when new.
http://www.universal-radio.com/catal...xvrs/1153.html
Price dropped to $300 today...
Old 06-25-2010, 10:52 AM
Bump the thread
Looks like the seller of the IC-2800H dropped the price to $300 today. That is a steal.
Old 06-25-2010, 11:06 AM
That's a looking rig...I need something for the 40 but I don't think that would hold up well in a FJ40 environment...
Old 06-25-2010, 11:07 AM
Yeah, probably not a great choice for a FJ40. Paging Jacket! Add a Bytronics Tinytrac with GPS and you have most of a FTM-350 for about $250 less. No Bluetooth or wideband FM (broadcast) RX.
Old 07-05-2010, 06:36 PM
As the title reads, new in box Yaesu vx-7r.
I bought this in March for $320, never used.
$285 shipped.
http://expeditionportal.com/forum/sh...ad.php?t=45783
Old 09-01-2010, 09:19 AM
The current FT-60R is about $225, give or take. So this is not a fantastic deal if it needs a new battery, although since the original was NiCad and you can get NiMH replacements for about $30 it wouldn't be too bad if you talked him down. Also the FT-50R could take a 6 x AA holder and run (IIRC) the full 5W. So if you found that holder you could just use rechargeable AA cells and not worry about the custom pack.
Dual band amateur radio - $150 (Monument)
Yaesu FT-50R dual band hand held transceiver. This radio is practically new. Comes with a 4 AA Clamshell, car charger and the home charger. The regular batt needs to be renewed because it does not hold a charge.
Please call or Txt Tim with any questions. 719-290-3800.
Old 09-01-2010, 09:21 AM
Kenwood TM-732A Dual band mobile w/Duplexer - $225 (Parker)
Ham radio for sale: Kenwood TM-732A Dual band (2-meter/440) Transceiver. With Diamond MX-72D Duplexer. Have Orig. box and manual for radio. Nice condition, fully functional. $225 obo.
The Kenwood TM-732A dual band 2 meter, 440 MHz transceiver provides high performance communications with operating ease. It features dual receive including V+V and U+U, built-in DTSS and page functions, 50 memory channels and multi-scan functions. The high visibility front panel is detachable. Extended receive range is 118-174 MHz and 438-450 MHz. Power output is 50/10/5 watts on 2 meters and 35/10/5 watts on 440 MHz. 5.52 x 1.6 x 6.3 inches 2.4 Lbs. (140x40x160mm 1.1 kg). Requires 13.8 VDC at 11.5 amps. MC-45DM multifunction DTMF hand mic included.
Features
* 50 Memories
* Scanning
* CTCSS Encode
* S Meter Squelch
* Auto Power Off
* Cross Band Repeat
* DTMF Memory
* Triple Tone Alert
* DTSS Pager Function
* DTMF Hand Mic
Old 09-03-2010, 07:07 PM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
Opinon's needed:
Thinking I need a hand held with external antenna for the Tundra so I have communication to and from the trail. What would you suggest?
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
