Old 05-21-2010, 01:29 PM
Default 80 series rear cross member
I've followed enough 80's on the trail to notice that even with an aftermarket bumper, the butt on those rigs drags over a lot of rocks. I assume this is largely because the rear cross member extends several inches beyond the body, and thus you cannot tuck a rear bumper nicely below the body and gain valuable departure clearance without cutting the frame.
So I guess my question is whether this is a common modification (cutting the frame), or why someone wouldn't do it? I spend 0 time in the 80 section on Mud, so don't hold it against me if this is a newb question.....
Old 05-21-2010, 02:15 PM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
You getting an 80?
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 05-21-2010, 02:42 PM
makes mounting a spare tire carrier difficult. mine was cut off at the tailgate when i got it. i have a bumper now that will handle being drug, so i don't care.
Old 05-21-2010, 03:02 PM
powderpig's Avatar
I really do not think a couple of inches makes that much difference. To make a good difference, you would really need to bob the back end and loose about 16 inches of the rear. It a wagon, it has overhang. Put some metal on it and drag it.
Old 05-21-2010, 03:27 PM
Yeah it's a pretty common mod- the 4x4labs bumper requires it, for example, among others, see http://www.4x4labs.com/products/rear-bumpers/ The easy argument is the new beefy bumper is way stronger than that cross member was... so cutting it shouldn't involve much heartache.
But I would side with here, I have less lift than him and smaller tires, and still don't think the overhang is that bad for how I use the truck and heck I've got the worst production aftermarket bumper available in terms of departure angle (Kaymar). Ok, second worse, the ARB one would be #1.
But still, a little butt drag hasn't seemed to slow me down much, and I've eloquently dragged it across several rocks in Colorado, Utah, and California.. so like a lot of possible mods out there this one probably isn't for me.
Old 05-21-2010, 03:32 PM
I looked at picture earlier of a rear bumper scrape, and it struck a memory of watching Neil throughout Devils Racetrack. Just thought I'd ask...no disrespect to the 80 owners
Old 05-21-2010, 08:28 PM
Bikeman Bikeman is offline
It is one of the best mods I have done, that is, cutting 3.5" off my frame and making a new crossmember out of rectangle stock and having tube bent around it.
I have a better departure angle than an 80 with a swingout with 8" lift and 40's.
Nay, care to chime in?
Mike
2001 Honda XR400 with goodies
Old 05-21-2010, 08:38 PM
Convert's Avatar
Convert Convert is offline
I took 4 inches out of the frame and added a cross member when I built my rear bumper and it does drag less IMHO
Dan Reinmuth
47 Bantam Trailer/RTT
71 FJ40 project
TLCA 13269
KØVRT
Old 05-22-2010, 08:05 AM
LARGEONE's Avatar
LARGEONE LARGEONE is online now
I'm a dragger as well!!! My spare tire is mounted so low that it actually hits before my bumper does...not a good thing as it torques the swing-away when it drags. It's on my list of summer projects and is THE reason I bought my welder!!! No plans to chop the cross-member at this point.
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
Old 05-22-2010, 08:43 PM
While mine is not an 80. 100 frame is pretty much the same. Rear cross member and 2" were cut of the back of my 100. Does a couple inches make that much a difference? When the only offering of a lift is 2.5" you bet. It surprises me more people don't do it. For me it was about still being able to use 2" receiver and have a reasonable departure angle.
http://www.youtube.com/watch?v=NMM8ckE5sCQ
