Old 05-22-2010, 09:51 PM
jolee jolee is offline
Default abs activating just before stopping
1997 80 series I can feel the abs activating just before the vehicle stops. On IH8MUD they talk about cleaning the sensor magnets where are the sensors and how hard to clean are they. Thanks for any help.
Old 05-22-2010, 09:54 PM
they are on the top of the knuckle on the backside. one bolt holding the plastic sensor in the knuckle housing.
Old 05-22-2010, 10:07 PM
on IH8mud they talk about metal and grease on the magnets is that from wear on the birdfields
Old 05-23-2010, 09:24 AM
coax's Avatar
coax coax is offline
http://forum.ih8mud.com/80-series-te...tml#post923535
-Corey
'74 project pig (sold)
Old 05-23-2010, 09:54 AM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Yea haven't read the ih8mud artical. But that issue will happen if your sensors arnt reading the same speed. It might be a damaged sensor or ring. But problly just fouled with contaminates. Worst case controle moduel, but douptfull
TLCA # 20314
Step by Step Bed Bob
