Old 05-29-2010, 10:05 AM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
Default Roof Rack Clearance
Is there a minimum space I should have b/w my truck roof and the ConFer roof rack? I know I need the obvious minimum amount for the bars to deflect and not hit my truck, but I was more wondering if I need a certain amount of space to allow for air/wind to pass under the rack? I'd like to lower my rack so I can still get the truck in the garage.
My plan...add a bottom sheet to the rack so that things don't fall through. As it is right now, there are only the three cross members that don't really hold anything in the rack!!! Then, lower the mounts about two inches which would leave about 1/2" between the rack and the truck. Any issues with this?
TIA
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
Old 05-29-2010, 03:46 PM
I'd put the rack as close to the roof as possible without damaging the roof. Air flow between the rack and the roof is lost power at highway speed.
Old 05-29-2010, 06:30 PM
LARGEONE's Avatar
Thank you, Bruce...this is what I was wondering. I'm going to try to lower it a bit and hope that it will fit in my garage with the rack on after I'm done. I may need to buy a couple more attachment brackets from Nathaniel?
Paul
KE0OLZ
Old 05-29-2010, 07:33 PM
Chris's Avatar
Chris Chris is offline
I've a home-made rack for my RTT so it'll clear the garage. There's just enough room to reach underneath to attach the mounting bolts, 2" from the root top to the bottom of the rack. I can pull into the garage.
Found that I cannot back in to it though.
Old 06-01-2010, 11:17 AM
Don't forget to account for the weight in the rack (gas cans, tires), and the flexing from offroad use - re: clearance between the rack and roof.
Old 06-02-2010, 09:18 AM
Caribou Sandstorm's Avatar
I have a Front Runner double gas can holder, brand new, never installed..
If you want to buy it for your rack? Does not work with my plastic Sceptor cans..minor detail..
I paid 100.00 for it. Yours or anyone elses for 80.00, will bring to the meeting tonight, if you or someone else wants it.
Chris
2001 UZJ100 Mel's rig now!
2016 Tacoma TRD OR DBCSB
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
