Old 05-31-2010, 11:28 PM
baja1d's Avatar
baja1d baja1d is offline
Default 4 on the tree
Has anybody installed one of these yet? If so, please give the low down.
http://forum.ih8mud.com/40-55-series...ts-4-tree.html
Old 06-01-2010, 11:40 AM
It's a cool idea and being able to keep the trans tunnel clean without cutting would be nice. Plus you get the cool old school factor with the column shift. Sounded like the problem is with making the linkage work and still being able to keep the trans tunnel unmolested since there is a clearance issue with the 4 speed. Mark mentioned having to either modify the tunnel or add a 2" body lift to clear it.
