Old 06-03-2010, 09:06 AM
baja1d's Avatar
baja1d baja1d is offline
Default Need Help-Extra Axle Parts???
Extra Axle Parts???
After reassembling my '76 FJ40 front axle I came up w/ these two metal rings. They seemed a little too stout to be the reminence of an old seal that I removed and I'm concerned that they're suppose to be in the axle and not on the work bench! Any ideas and orientation pictures would be helpful.
Old 06-03-2010, 09:53 AM
Those kinda look familiar to me, as if maybe I pulled some of those out of my axle as well a few years back when I did my first front axle service. Maybe some kind of bearing retainer?
Old 06-03-2010, 10:01 AM
baja1d's Avatar
Got an answer on Mudd:
"Don't worry about them.
They were used for a very short time with a different style front wheel bearing seal."
Old 06-03-2010, 10:49 AM
Blackdiamond72's Avatar
Blackdiamond72 Blackdiamond72 is offline
Ditto, found them when I did the mini truck disk conversion on my 69. They fit into the old bearings.
James in Black Hawk
1969 FJ40 (Black, for now) 33" MT/Rs, 4"Suspension, 2" Body, 75 2f
2001 Taco Double Cab
"Get Busy Livin, or Get Busy Dyin..."
"Sport Utility Housing!"
Old 06-03-2010, 11:02 AM
Up, hub bearing washers. You don't need them
