Old 06-13-2010, 02:55 PM
I'm at I25 and belleview if you want to check it tomorrow... I'll bring the scan gauge with me.
you can buy a reader for ~$40.. with an 80 you'd might as well buy one.. you'll be clearing the 401 regularly
http://shop.advanceautoparts.com/web..._T|GRP2018____
Old 06-14-2010, 07:43 PM
girraffe girraffe is offline
well i disconnected the battery and the light is gone. upon initial start the motor revved up three times and then went back to normal. it actually idles a little lower now too. if(when) it comes back i let yall know...
Old 06-14-2010, 10:20 PM
Romer Romer is offline
Thats because you reset the computer. Would have been much better if you had the code pulled so you knew what it was
Old 06-15-2010, 08:14 AM
Nemo Nemo is offline
I have a reader as well and I live downtown for the most part if that is closer for you. If it doesn't come back then it sounds like the PO may not have cleared the codes after replacing the O2's but most likely not the same. It will come back after so many miles. I think it is like a 3 trigger component meaning that the event needs to register 3 times prior the light coming on so you may already have a stored code.
97 Crusher, Slee'd 6 inches, All 3 Factory Diff locks, Hanna Sliders, Slee F&R Rock Crushers, M12000 Oops, I did it again saver -- SuperCharged.......0-60 in 5 seconds,
"Tractor in a Tux"
What Did the Five Fingers Say to the Face.....
Old 07-16-2010, 01:16 PM
ok the code came back. its the dreaded P0401... think i will just drive it with that till i do my motor swap... thanks yall
by the way the motor/trans and either HF2A or HF2AV will be up for sale this fall. motor will be throwing a P0401 he he
Old 07-16-2010, 02:07 PM
They've carved out a special place in hell for me no doubt, but I ended up fixing my 401 for free, by disabling the EGR sensor and making it so it's "on" all the time.
http://www.risingsun4x4club.org/foru...&highlight=401 is the tread, which includes some supporting mud threads, if you really want to get into this your answer's probably in there.
