Old 06-29-2010, 11:10 AM
both tre have threads on each end (unless I missed where you used 2 rh (or lh)) tre. build it with the middle bolt (threads) removed. You can still adjust the rod without it, no?
WØREK
Old 06-29-2010, 11:32 AM
Ah.
I see what you meant. The reason that I have the middle bolt is because the whole unit has to clear the center link. The part on the left with the jog in it has to remain stationary, so the tre is only there to attach it to the center link. It cannot be rotated because of clearance issues. There will be a jam nut holding it stationary. The center bolt and adjuster sleeve will be used to adjust toe.
Old 06-29-2010, 06:03 PM
sleeoffroad's Avatar
Isaac, do you have ball joint spacers on that truck?
Christo Slee
KØSLE
www.sleeoffroad.com
Old 06-29-2010, 06:11 PM
yes, but its currently sitting at stock height. I relaxed the torsion bars to allow the suspension to travel a little easier and give a bit better ride.
Old 06-29-2010, 07:29 PM
J Kimmel J Kimmel is offline
seems ok, I'd make a couple of spares though.
Old 06-29-2010, 08:15 PM
I've been looking at it, thinking, looking at it, thinking.
I'm going to do something different. This just isn't cutting it for me. I want to get rid of the weak link, not wonder if I did.
Really what I think I need to do Jeremy is get a couple of 60's
Old 06-29-2010, 09:18 PM
we can swap an axle under there in a weekend...just sayin...
Old 06-29-2010, 10:42 PM
Its not a matter of time. Its a matter of money. I don't want the "same old" so my plans for a swap entail waiting until after a certain gets done planning a wedding
Old 06-29-2010, 10:51 PM
makes sense, I'm all for waiting and doing it once...there are very few ways I would do it for myself anymore
Old 06-29-2010, 11:01 PM
Word.
I do a lot of web-fabbing by reading a lot of other builds. I like to think of new ways to do stuff, although, as my current rig shows example of, that isn't always the best way. In fact, I've learned a lot about what doesn't work well by putting it on my rig. LOL
I figure by the time I'm ready to swap, I'll be able to hit the nail on the head.
