  #51
Old 07-12-2010, 11:14 AM
Originally Posted by FJBRADY View Post
Curious, what's the reason for "cooking/heating" the metal?
Less chance of ruining the heat treatment or creating new internal stresses or warping.
  #52
Old 07-12-2010, 11:17 AM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
Less chance of ruining the heat treatment.
Makes sense. Thx, Dave!
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
  #53
Old 07-12-2010, 11:24 AM
Preheating and/or postheating are usually required when dealing with certified welds, like pipelines and pressure vessels. Also helps make sure the material is absolutely free of moisture or condensation. That has a couple of problems, one is obviously from the popping, but water introduces hydrogen into the weld which creates metallurgical issues, too. FWIW, it's stuff like this why I am strictly against using bumpers and sliders as air tanks. Even if the welds seems nice and the design is free of pressure risers (like say all corners are round), all it takes is one small mistake to create a potentially dangerous fragmentation grenade.
  #54
Old 07-12-2010, 11:37 AM
Thanks Dave! Obviously I was just going off of recommendations.
Steve, the other reason for heating before the weld is because of the material thickness.
Don't quote me, but I have read that you can weld thicker material with a smaller welder the hotter the material is.
My MM175 is a great little box, but it starts to struggle at 3/8". Because I was welding 1/4 to a 1" rod, I wanted it as hot as possible to start, so that I would get adequate penetration on the welds.
The other reason was that this is a forged piece.
As far as I know, forged pieces of steel are cast steel that is then re heated to red hot, then smashed over and over again with a huge hammer. These days' the hammers are huge machines with forging plates that are in the shape of the part.
Forging re-aligns the metal crystals inside the part and generally makes the part more resistant to cracking and fracturing.
Again, don't quote me on that.
However, in the event that there were any imperfections in this part, heating the piece before hand helps to ensure that the welds will not induce areas of stress and cause the piece to crack next to the weld.
A common thing in the off road world is to link dana 60 axles under trucks. However, the 60's often have cast housings, which means that if you weld to them cold, your link tabs will just crack off. However, heating the housing with a rosebud before welding, then running the weld, and then re heating will eliminate this issue.
I figured, preheating and post heating, even this little bit, couldn't hurt, so I gave it a shot.
  #55
Old 07-12-2010, 12:03 PM
You can also "peen" cast parts as they are cooling to prevent cracking. I have done this before and it works well.
  #56
Old 07-12-2010, 12:21 PM
If you are in the presence of good blacksmiths and metalworkers it's really pretty amazing to watch how using a rosebud, hammer and anvil demonstrates in 5 minutes what all the textbooks and classes in the world try to explain about internal stress creating and reliving.
That's a good point, AFAIK it never can hurt to do.
  #57
Old 08-01-2010, 11:01 PM
So, bummer thing about having a house now is that sometimes I get wrapped up in house projects and the truck sits for a while. But, this weekend, I got some time, and Baby Beast is driving again! Though, in desperate need of an alignment.
Couple pics:
Painting:
I trimmed down some of the gussets because there was going to be clearance issues. Also, a little lighter this way LOL
I then spent some time taking off the nuts on both the idler and steering box, and put on loctite, and torqued them to 70 ft lbs. Hopefully that is good. But I'll be checking them from time to time.
Then, it was assembly time.
HUGE thanks to Ben and Christo at Slee for running taps down my threaded inserts. They are a good product (the inserts), but I do not think the sets for the 80 rod ends are very practical. They warp too easily.
Anyway, all assembled:
Much beefier. These shouldn't bend (I hope)
And, the truck. I gave the T-bar's a couple of turns to level things out just a bit. WAY out of alignment now.
  #58
Old 08-01-2010, 11:11 PM
Cheese Cheese is offline
Send a message via AIM to Cheese
And that my friend is why you're the man!
Looking good, I am impressed.
Adrian Flygt
Sold 4Runner, thanks meth heads.
"There's a feeling I get when I look to the west and my spirit is longing for leaving..."
www.sleeoffroad.com
www.sonoransteel.com
  #59
Old 08-02-2010, 01:19 AM
Baby Beast is getting beastly! Nice work dude!
  #60
Old 08-02-2010, 09:09 AM
RockRunner's Avatar
Looks great, nice job on the design. I do have a question for you, what is the weakest part in your steering set your now? The reason I ask is simple, I have build up my drive train preity stout but I use so so U joints so in case I romp a little to hard the U joint will break but save the rest of your drive train.
PS I really lke the BBQ idea, at first I thought I was looking at knives being made.
Thanks T aka Tom KR0MPS
TLCA #6136
