Old 07-06-2010, 05:28 PM
On the other end of the spectrum is shot peening. Using larger media is an effective way to work the surface of metal. Some leaf springs are shot peened to reduce surface stress which reduces the formation of cracks and improves the life of the spring.
Old 07-06-2010, 07:54 PM
I use 60 grit Aluminum Oxide to sand blast memorial engravings in my park. There are all different blast materials with different abrasive qualities, similar to sand paper. Roughly 90psi-125psi is used. If the metal on the cabinets is thin I can see how it would deform them.
Old 07-07-2010, 09:46 AM
Also - the worst thing to sandblast, from a distortion perspective, is a big flat sheet of metal. You'd have been ok, I think, if you had them sandblast a curved front FJ40 fender or something that had some inherent strength from its shape.
Old 07-07-2010, 01:38 PM
FJ 432's Avatar
FJ 432 FJ 432 is offline
I appreciate all the comments. I went into this project thinking that sandblasting is all the same with one exception, different media. I will know better the next time.
