Old 07-22-2010, 11:55 AM
timmbuck2's Avatar
Originally Posted by hulk View Post
man, That Scares Me To Death. I Bet You Guys Have A Lift That Would Prevent The Truck From Falling No Matter What. Jack Stands Don't Seem Quite As Reliable, Especially When You're Putting All That Torque On Them.
X2!!!!!
* 00 LC
* 99 Saab Convertible
* 76 Piggie
* 1996 T-100 with 396k miles
has a 2008 FJC
KDěTIM
Old 07-22-2010, 01:21 PM
timmbuck2's Avatar
from a guy on MUD:
Originally Posted by redcard View Post
is it a speedo noise? I have a strange sqeak on mine too, havent figured it out yet.
I was suspecting my speed sensor on the tranny
* 00 LC
* 76 Piggie
has a 2008 FJC
KDěTIM
Old 07-22-2010, 01:32 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Thats what the break peddle is for. Your not going to be flooring it from a stop you just rolling it to it. There Isn't any torque on it like this unless our being foolish. And we use the alignment rack which is the same thing as safety jacks. Because you need the suspention loaded. To mimic driving on the road. If your squeamish face the truck towards the street, jack it up, and drive it to 40 or so b4 getting under it at 15mph. To get a feal for how it reacts on stands. You can also shake and rock the living s**t out of It motor off to see if its tipsy. I assure you its not.
TLCA # 20314
Step by Step Bed Bob
Old 07-22-2010, 05:03 PM
squeeky drive shaft could = bad u joint
Randy Rosetta KDěKWX TLCA #19351 NOW 2015 Rubicon Hard Rock & (2) 1970 Boss 302 Mustang's THEN 69 FJ40 Buggy "Meanie", Mini-truck "Gecko" & 74 FJ40 "Blue Mule"
Old 07-22-2010, 05:06 PM
timmbuck2's Avatar
I am leaning towards this...
So I can pull the front drive shaft as long as I keep it in 4 wheel low, right? Don't need to go very fast to see if it is still making the noise...just would need the center diff lock switch if I was going to keep the driveshaft off...right?
* 00 LC
* 76 Piggie
has a 2008 FJC
KDěTIM
Old 07-22-2010, 05:23 PM
Disappointing
Right. If you don't have a CDL switch, putting it in Low will engage it.
1996 FZJ80 Ě TLCA #4189 Ě WěRDY
www.rustybrain.com/cruisers Ě my Rising Sun bio Ě Facebook Ě Twitter Ě LinkedIn Ě Need satellite Internet? Check out: Exede Internet
Originally Posted by nakman
Old 07-22-2010, 05:26 PM
For testing purposes, straight line, yeah shifting into low would work...
5 mins of work and you could use the hazard switch as your CDL switch (I think you need to do some trimming though) or the other route is to shift into low range to lock the center diff, pull the fuse, and then shift back into high. I think I would do this and avoid any potential for more noise being introduced by the center diff being in low.
Old 07-22-2010, 05:27 PM
timmbuck2's Avatar
5 mins of work and you could use the hazard switch as your CDL switch (I think you need to do some trimming though) or the other route is to shift into low range to lock the center diff, pull the fuse, and then shift back into high. I think I would do the later and avoid any potential for more noise being introduced by the center diff being in low.
which fuse?
5 minute fixes are very rarely 5 minutes for me.
* 00 LC
* 76 Piggie
has a 2008 FJC
KDěTIM
Old 07-22-2010, 05:28 PM
You should also be able to just use the hazard switch, if you want to stay in high range. I know many have opted to get a second hazard switch for their CDL, since they're cheaper than a CDL switch.
edit: dang, you guys are quick!!! beaten by Corsair..
Old 07-22-2010, 05:46 PM
which fuse?
Me either - Call it a 30 min swap
As for the fuse, looks like it is the big 30a fuse, #14 in the panel by your left knee
FZJ80 Fuse Chart - This is a chart for a '94 but should be similar/same I'm thinking
