Old 07-21-2010, 02:43 PM
Red72FJ40 Red72FJ40 is offline
Default What OEM Carb in a '72 1F FJ40
Does anyone know what OEM carb is in a 72 FJ40 with a 1F and where I can get a rebuild kit, or where locally I could get it re-built?
Thanks.
________
headshop
Old 07-21-2010, 03:02 PM
There are several years that could work in an F engine. I've run a November 69 and Sep 72 Aisin carb on my F engine. I believe that even the 2F carbs could be made to work, but there are more systems on these carbs and I don't know the details on how to "bring them down" to F engine use.
Rebuild kits are available at NAPA, but there are differences in kits. I would recommend getting a Keyster kit that is specific to the carb. Cruiseroutfitters sells them.
There are a few in the club that have rebuilt carbs and I'd be willing to give you a hand. I rebuilt my first carb last fall and rebuilt a 22R carb earlier this year.
Do you already have a carb?
Old 07-21-2010, 03:16 PM
The Aisin carbs have a three/four digit code stamped on the air horn that indicates when the carburetor was built; digit 1 is the year, digit 2 is the month and digits 3/4 are the day of the month.
So, I am pretty certain that the OEM carb that was in a 1972 would have a 1 (1971) or 2 (1972) first digit on the code.
However, keep in mind that with trucks this old, it is very rare that they have survived in tact and with the same engine, carb, steering wheel, seats, etc.. that they left the factor with.
Old 08-03-2010, 09:57 AM
Hi Ricardo, been tied up so I have not had a chance to look at it, but I did last night.
There is a logo on it that I thought said Atson (sp) but could have been Aisin? Not sure as it is hard to read. Also, on the top of the carb there is an ISO (or 180) cast into the aluminum and below that is stamped 2D2.
Does any of this make sense or should I be looking in a differnet area. FJ Serial number indicates the truck was made in 4/72.
Thanks for any insight.
________
volcano vaporizers
Old 08-03-2010, 10:13 AM
From the description, it sounds like this is the original carb. The 2D2 would indicate the carb was build on April 2, 1972 consistent with the truck's serial number.
Old 08-03-2010, 03:55 PM
Thanks, Ricardo.
Would I just go down to NAPA then and ask for an OEM carb rebuild kit for that year FJ40? Would anyone recommend a different aftermarket carb or should I stick with the OEM?
Thanks!
________
toyota corolla
Old 08-03-2010, 05:19 PM
You could go to NAPA, but I would recommend calling Kurt at Cruiseroutfitters to get a Keyser kit. The Keyster kits are more comprehensive in their content that what is available from NAPA.
My recommendation would be to stick with the OEM carb. If you'd like a hand with rebuilding it, I'll be willing to work with you.
If you want more of a turnkey approach, you could send your carb out to Mark A. or Jim C. for a full rebuild. Both of these guys really know the stock carbs and can get them in tip/top shape. Alternatively, you can purchase one of the TrollHole carbs.
Switching to an after market (Weber) will be more $$$ than sending it out for a rebuild or the TrollHole carb.
I'm sure others will chime in with their perspective.
Old 08-04-2010, 10:35 AM
Thanks so much, Ricardo, for your offer and information. I really know zero about carbs so I would not be of much help re-building it so maybe the turnkey approach would be better.
Can I ask your opinion on one more thing? The current carb seems to work fine once the truck is warmed up. No issue at all with it. It won't start though (w/o starter fluid) and it stutters on acceleration when it is cold. I'm thinking it is carb related but is there anything else I should be looking at?
Thanks again for your time and help.
Pete
________
FZ750
Old 08-04-2010, 10:36 AM
vacuum leak?
Old 08-04-2010, 10:50 AM
Pete
vacuum leak?
It might be the choke mechanism. You should have a choke knob on the dash. When you pull it out, it closes a plate over the primary barrel. As the truck warms up, you push the knob back in. The symptoms are consistent with what would be expected if the choke is not used or not working.
To inspect the choke, remove the air cleaner from the top of the carb. You will see there are two barrels in the center of the carb and one of them has a plate. Get inside the truck and pull the choke knob. Get outside the truck and look at the top of the carb again - you should see the plate has moved to cover the barrel. Get inside the truck again and push the choke knob in - this time when you look at the carb you should see the plate has moved and the barrel is open.
When a truck sits a long time (don't know if this is your situation) the cable will stick and not close the plate. It is also possible that the choke cable is missing or not connected to the carb linkage.
Wes is also correct about a vacuum leak being a potential problem, but I would first look at the choke. Post up with what you find.
