Old 07-26-2010, 03:14 PM
CardinalFJ60's Avatar
Default just say no!!
Just say no to "thermal events" in your toyota.
Old 07-26-2010, 05:07 PM
There is no risk with using a wire gauge larger than your minimum requirements as long as the lugs in your fuse block can accomodate it. The risk is when people start using larger fuses than what the wire size is rated for. Then the wire becomes the fusibile link and the risk of fire increases.
Yep...using the right/correct size fuses
Just my main power and ground to the aux fuse block is bigger than I need apparently...The runs coming off the fuse block are typically 10ga although those are probably overkill based on what I'm reading here
But it must work...CB, HAM, fridge, etc. all powered off the aux fuse block and no noise/problems so I'm happy
