Old 07-25-2010, 08:57 PM
Romer Romer is offline
Kevin, to be clear. I agree with your recommendation on Castor correction and shocks. I Bet Corbet bought a kit so hopefully that all came with it
Extending Brake lines is a good idea and Extending Diff Breathers and the tranny/tcase breathers is a good idea so you don't suck water into your junk, not related to a 2.5" lift. Course you do put more "POWER" into your offroading than most so you might have a different perspective
Long day, so my other post may have come off to harsh.
Old 07-25-2010, 09:12 PM
Dr. Schlegs's Avatar
I'm just trying to offer the lad info so he don't break on the trail. I like to call it midwest wheeling - but I am learning the finer art of "crawling." I have ARB lockers on my to do list you know. Hulk informs me these will add to the appearance of finesse. No blood not foul, we all have days like that once and a while.
TLCA#5366
Old 07-25-2010, 09:48 PM
Yes, I aquired a complete kit including the steering dampner, caster correction bushings, shocks, as well as the springs.
I did not mention the others as I did not have any questions regarding their installation
I will address brake lines and the such after installing the lift if needed.
I'm really looking forward to getting this installed. My front axle currently sits less than 1" off the bumpstops at rest, about 2" on the rear. Makes for an unpleasant ride around town. The springs I got are rated for an extra 242lbs front and 660lbs rear over stock. Given the extra weight on my truck I feel this will bring me back closer to stock ride quality with some extra clearance.
Old 07-25-2010, 09:50 PM
Nay's Avatar
Nay Nay is offline
Back to the original question, I just use a 4' breaker bar to get the spring over the lip and then kick it into place.
It saves you a ton of time trying to get that last inch of droop if you need it. A long crowbar can work as well.
Spring compressors are an incredible waste of time for the remote chance you may kill yourself wasting that time
Old 07-25-2010, 10:02 PM
Corbet - When Ige and I did my lift - she pulled out the cherry picker and lifted each corner individually. Never took a tire off - it was slick!!!!!!!!!!!!!!
TLCA#5366
Old 07-26-2010, 01:59 AM
Corbet...I can't remember what all you have hanging off the front, and rear, or your truck but hopefully you have an ARB/Slee bumper and winch up front and rear bumper and lots of weight in the back to bring that sucker down
Is the Ironman lift similar to OME in that you get X amount of lift based on loading up the springs as suggested? Just asking 'cuz when I installed the OME heavy lift I got a fair bit more than the 2.5" because I wasn't at the recommended weight rating of the springs yet.
Old 07-26-2010, 08:37 AM
I'm missing the rear bumper for now but hopefully by spring no longer. I. regularly exceed 6000lbs, daily driving, on the scale so I think I have the weight for these springs. I packed as light as possible for CM10 and weighed in at 6680 as I left town. I basically brought my backpacking equipment for the most part. When I add the rest of the family I figure 7000+ is just around the corner.
Yes, the Iron Man lifts are like OME in that you should get x amount of lift based on weight of your truck. I figure I will net 3" due to how much my OEM springs are sagging.
Old 08-04-2010, 08:18 PM
Springs are in but looks like I need to swap them right to left. I'm leaning towars the drivers side about 1"
Before & After shots
Old 08-04-2010, 08:20 PM
Need to pick up a pickel fork tomorrow to install the steering dampener and then deal with this lower rear shock mount. PO had new rear shocks istalled at one time. Mechanic must have lost the OEM bolt and the one he replaced it with was not up to spec. Wife always asks me why I hate having other people work on my truck. This is a perfect example.
I plan a full write up and review to follow on MUD once completed. Eli from Camel 4x4 requested so as this is the kit that was raffled at CM10.
Old 08-05-2010, 09:27 AM
Looking good Corbet
