Old 07-26-2010, 04:27 PM
TonkaToy's Avatar
TonkaToy TonkaToy is offline
Default tire valve stem 'covers'
So, I have a compressor for 'end of trail' refills on my tires.
I was on a run a while back and saw some of the guys had these valve stem covers that were real easy to work with on deflation. I seem to recall, they just twisted them and they started the deflate, twist them again when you're done.
Any idea where I might get a set of these? Did I imagine it?
I got the pump from Harbour Freight so hopefully, it will serve my needs!
I will find out Saturday on the 40's only run, I guess!
Thanks
Old 07-26-2010, 04:37 PM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
You could spring for Stauns, which I have, but I use the cheapo terraflex ones all the time. I would recommend the terraflex ones.
http://www.parksoffroad.com/prodrevi...flatormain.htm
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 07-26-2010, 04:41 PM
Thanks
I have these on my 40 and I love them! I also have short rubber ones on the same wheel that I put the pressure gauge on.
http://www.polyperformance.com/shop/...t-p-16505.html
These are much cheaper and work pretty good for what they are...
http://www.parksoffroad.com/prodrevi...unevraduse.htm
Old 07-26-2010, 05:48 PM
I have the Stauns, but I really dig this little guy:
http://www.parksoffroad.com/prodrevi.../ezdeflate.htm
It may be what I get for the 40.
Old 07-26-2010, 05:50 PM
That what I use in my 80....I really like it! I should have an extra one I had in my 40 with the previous wheels if you wanna try before you buy.
I have the ARB deflator that removes the valve core while the special gauge thing is screwed onto the stem. Works well
Old 07-27-2010, 12:21 AM
TonkaToy's Avatar
Thanks for all the responses. I will try and get down to the 4 Wheel parts store this week.
Hope to see some of you on Saturday!
