Old 08-06-2010, 09:37 AM
I think that's why it's leaking out is because it's goop...
WØREK
Old 08-06-2010, 11:52 AM
treerootCO's Avatar
Event Coordinator
The diff was overfilled so that could have added to the creation of birf soup. I'll have to check where the fill plug is in relation to the axle seals but the 90 weight gets in there on a regular basis. I know mine dropped a lot of 90 weight when the rig was slightly leaning toward one side. We knew the failure there because the wheel fell off. Did you fill the diff and then add the lift? The caster correction rotates it slightly so that may be why you were able to over fill it on level ground.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
