Old 08-05-2010, 12:06 PM
LETSROLL's Avatar
LETSROLL LETSROLL is offline
Default Hi Lift Jack Question
I'm about to go and buy one but thought I'd post a question here. I see them for sale at McGuckins, Jax, Murdocks, etc. Are there different model numbers/types? If so, which is preferred?
Thanks
LETSROLL
John Glidden, Boulder
TLCA#19430
1996 FZJ80 Locked & Lifted, ARB Front, Slee Dual Swing Arm Rear, BFG ATs on FJC Wheels, Speski Barrier
2005 Subaru Outback XT
1997 FZJ80 Collector Edition
Old 08-05-2010, 12:09 PM
I like the all cast but any will do..
http://www.hi-lift.com/hi-lift-jacks...omparison.html
Old 08-05-2010, 12:32 PM
The lifting parts are the same, the cast version has a couple of nicer parts (base and top clamp). I have a stamped version and have used it a lot because of the lack of a winch for a long time. The stamped parts are plenty strong.
The main thing IMO is to get the Bloomfield Manf. Co. made 'Hi-Lift' brand, this is the real one. There are things like jacks and recovery gear where I prefer to know pretty surely that the ratings are true.
Old 08-05-2010, 12:53 PM
I'm with Dave. If it says Hi-LIFT on it, it'll be fine.
3 flavors:
stamped
cast
Extreme
2 common lengths
48"
60"
I've used a 60" jack once where a 48" jack would NOT have worked. but the 48" jack fits in my truck much better.
I say get a used one at the rally this weekend.
dollar an inch for one in good shape is a good deal.
KD0FDS
Stephen
Old 08-05-2010, 04:35 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
I like the 60" because I can see myself using a 48" and saying man I wish I had a 60". But never see myself using a 60" and saying man I wish I had a 48"
TLCA # 20314
Step by Step Bed Bob
Old 08-05-2010, 04:57 PM
Hard to find places for a 5' jack! A 48" and a short chain will lift nearly anything you need....it's all in the rigging. Example: When Isaac and I lost a inner bead on a rear wheel of WR my 48" was plenty tall enough to do what we needed and I have over 60" of articulation front to rear!
Old 08-05-2010, 05:00 PM
nakman nakman is online now
I've got a 57" hi lift.. it fits perfectly laying across the wheel wells behind the back seats. So far I haven't missed those last few clicks.. yeah I put a 60 in a band saw..
CardinalFJ60's Avatar
Default x2
I agree with this expecially after witnessing the recovery on Ehill. Think not only about jacking up the rig for tire change or repair, but also for recovery techniques. We had to stack some rocks under the 48" hi-lift (IIRC) to get the jack high enough to grab the roll-bar to help flip the gecko back over.
Old 08-05-2010, 07:13 PM
TIMZTOY's Avatar
Yep. Id rather have the headache of were to fit the 60" for storage rather than the headache of needing only 3-5 more inches on a 48"
TLCA # 20314
Old 08-05-2010, 07:47 PM
i have a 60" i leave at home and rely on one of you
