Old 08-13-2010, 03:22 PM
Chris's Avatar
Chris Chris is offline
PM'd you a couple guys Rob.
Old 08-13-2010, 04:39 PM
RedCreeper's Avatar
sounds like something is up with the mapp sensor. Have you replaced it?
Kenny Jones
TLCA #19056
08 TT FJC
82 Scrambler (Scraps)
81 Scrambler (Sassy)
07.5 Dodge Ram 2500
Old 08-13-2010, 04:56 PM
maxsdad maxsdad is offline
Thanks Chris!
Yep - replaced with same result...
Old 08-16-2010, 12:26 PM
RedCreeper's Avatar
Sorry for the time it took to get back with you. My buddy suggested cap, rotor and timing chain. this was before he knew about the mapp sensor. He also mentioned there might be a sensor in the ditribitor that might be acting up. When i told him about the mapp sensor issue he said to check the vacum lines for blockage or leaks.
Kenny Jones
TLCA #19056
08 TT FJC
07.5 Dodge Ram 2500
Old 08-18-2010, 03:06 PM
My turn to say sorry...been ultra busy...
The sensor in the distributor is the cam position sensor. We did look at it and clean it up a bit, but have not tried to replace it..I think there's a multi meter test you can use to determine whether it's working correctly or not - we'll look into it.
Checked all the vacuum lines - they are fine.
Thanks to your friend for his advice.
Old 08-18-2010, 03:08 PM
I finally looked at the Jeep I am driving today... and it looks like it is a different setup. the MAP sensor is bolted to the manifold...
Sorry bout that.
Old 08-18-2010, 03:17 PM
RedCreeper's Avatar
NP. Hope you get it figured out. I know on my old Jeep it was vacum lines that always cause my issues. But it was carberated also. Once i had a loose main power wire to the computer. Kept shutting off or ran like crap and could not figure it out. A month later of cussing and fussing and tow bills we found it. Hope yours does not take that long or is as much trouble. Let me know what you find out and if it stills needs a few ideas to figure out i can run it by him. Sorry if it is slow to get back he is in the middle of a house hold blending pot at this time. New lady and 3 new kids to go with his two.... DOH!
Kenny Jones
TLCA #19056
08 TT FJC
07.5 Dodge Ram 2500
