Old 06-30-2011, 11:10 AM
Originally Posted by cbmontgo View Post
Interesting. Got any pics of it?
No, I don't remember that it ever came on and I needed the real estate to mount my second battery when I added a big stereo in 1986. I found a picture of another one here:
This was from a thread here on a rig for sale last November:
http://www.risingsun4x4club.org/foru...ad.php?t=14561
Old 06-30-2011, 11:11 AM
Jeff, is your '76 a CA emissions-spec FJ40? I don't believe carb cooling fans became standard on Federal emissions-spec FJ40s until '79 or so.
Yes, Kalifornia spec.
Old 06-30-2011, 12:48 PM
cbmontgo's Avatar
cbmontgo cbmontgo is offline
Thanks for the pic, Jeff. Mine is a Federal spec, so I guess that might explain why it has no fan. These little oddities always crack me up how the FJ40 changes from year to year and region to region.
Wonder if mine is pre-wired to accept the fan?
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
  #24
Old 06-30-2011, 01:04 PM
My 10/76 Federal spec FJ40 isn't pre-wired for the fan, so I doubt yours is either.
  #25
Old 06-30-2011, 02:48 PM
cbmontgo's Avatar
That is too bad. I'd like to have had the plug and play option.
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
  #26
Old 06-30-2011, 03:33 PM
I thought my 10\75 fed had the plug but alas I can't remember and it's no where near me.
The good thing is you can easily mount an oem fan and just wire it up for a rocker switch which is better anyway.
  #27
Old 07-01-2011, 11:01 AM
I just re-checked the all images from that 40 for sale and it is a 76 unless the hard top is off another rig. It has the oval bezel so it has to be pre-79, but the rear side windows do not have the flip-out vents which were introduced in 8/76 (one month before the 77 model year) and it has the plate style spare carrier instead of the tube style which was also introduced in 77. It has the early non-full electronic ignitor which was only found on the 76 and 77 model years. It said the engine was out of a 1980 but the distributor is points type and has no cap vents so it must be from the 76.
  #28
Old 07-07-2011, 04:56 PM
FJ40zen's Avatar
FJ40zen FJ40zen is offline
I now have a Carter 4070 pump in mine. I cannot wait to test it all out on hot days. I need to finish my bodywork and paint before that happens. I figure that if it dies, I will leave the key on until it pumps fuel back into the carb unless there will be some great pressure keeping it from pushing the fuel from the tank. My fan burned up last year...
I am reviving an old thread here...
I have a '76 FJ40 with a 100% stock setup. I rebuilt the carb last winter and put a brand new OEM fuel pump in last summer.
She runs great, but I was up in Pike National Forest last week and stopped with the kids for about 15 minutes and she vapor locked for about 30 minutes before cooling enough to restart.
I am thinking that the electric fuel pump may be a good idea from what others have told me. Any particular make/model/flow rate/head pressure that you'd recommend?
Also, does higher octane fuel REALLY help?
1978 FJ40 ARB'd Front&Rear - 4.56 gears - 315/75-16 Kook's - FJ60 Steering Gear - Orion 4:1
Horsetooth 4 Wheelers
  #29
Old 07-07-2011, 05:35 PM
Phrog Phrog is offline
The picture above - engine with fan - is from my 40 (I bought
it Nov. 2010). It is a 1976, but the block (and block only,
as far as I can tell) is from a 1980. The emissions, distributor,
carb, etc. all seem to be original 1976.
I don't know why a PO installed the carb cooling fan.
The fan has never run since I've had it. Of course, that might be
because it's not wired correctly...I'll have to check that out.
-Phrog
  #30
Old 07-15-2011, 11:56 AM
-Phrog
There is a thermostat which mounts to a bracket on the plate above the manifolds. It connects (I think) to the computer which operates a relay to make the fan come on.
