Old 08-17-2010, 05:55 PM
PhatFJ PhatFJ is offline
Default Drive shaft work for my 40
Hi all, I just picked up a 1993 350ci with TBI injection that I am going to drop into the 40 in lieu of the existing 327. At the same time, I am going to get things set up right in the engine compartment and re-locate the motor and mounts. With this said, I will be needing the drive shafts reworked. Any thoughts on where I should take them, or should I consider replacing these (I think stock) shafts with new ones to handle the increased power and torque? Thanks in advance for the advice!!!!
Brian
KD0GEG
Old 08-17-2010, 07:52 PM
Chris's Avatar
Chris Chris is offline
Bill's Englewood Driveshaft Inc‎
3364 South Broadway,
Englewood, CO‎
(303) 781-0554‎
Old 08-17-2010, 07:59 PM
Thank you Chris! I appreciate the help..
KD0GEG
Old 08-17-2010, 08:06 PM
74fj40's Avatar
74fj40 74fj40 is offline
I second englewood!
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
Old 08-17-2010, 09:30 PM
I was just over at Englewood a couple of weeks ago, Bill rebuilt my rear driveshaft. Solid guy and shop.
Old 08-18-2010, 01:53 AM
Anyone know what the average turn around time is? Yeah, I should just call huh?
I've picked up a vibration that I thought was coming from loose wheel bearings up front...Well, those are tight now and I'm still getting a vibration - Next on the list is to pull the front drive shaft and see if the noise goes away - it is VERY speed specific in that I only the vibration/noise between 65-70mph, mostly on decel.
I thought it was odd that one day the vibration/noise was just there but probably par for the course.
Old 08-18-2010, 06:55 AM
Call him, but the week after July 4th I dropped mine off on Tuesday and he quoted Friday. That was complete retube, new u-joints, clearance & rebuild of the double carden, new splines. Mine had a twist in it I guess from the Rubicon and that was throwing it all off balance.
Old 08-18-2010, 12:05 PM
Brian
Depends on what you need done. If you are just changing the length go to the place in Englewood or Rocky Mtn Driveline.
Is your front axle cut & turned and/or is your rear pinion rotated upwards towards your T-Case output? Some times folks do those things but don't convert their DS to a double cardan joint and you will get vibration and premature U joint failure. Both of the outfits above can also do double cardan conversions.
If you want to go to a heavier duty DS (not a bad idea with a V8) go online and check out Tom Woods Custom shafts. His prices are competitive with the local places but he can build you a shaft that uses 1310 or 1350 spicer U joints that will give you a 30-40% increase in strength over the Toyota stuff. He also makes extreme high angle shafts if you need it.
Old 08-18-2010, 02:34 PM
Originally Posted by 74fj40 View Post
I second englewood!
I 3rd Englewood!
Old 08-18-2010, 02:35 PM
When I had both my front and rear done, they did it while i waited, couple hours. I called in advance to find out their schedule, and sorta made an appointment. It was a fascinating process to watch. Those guys are craftsman!
