Old 08-19-2010, 12:41 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Oh just lincon lock it and forget about all this goofy measuring crap.
TLCA # 20314
Step by Step Bed Bob
Old 08-19-2010, 12:43 PM
Just slap that lockright in. I'd say 99% are just put in. Most should be fine but if you want to do it right you measure and replace the thrust washer if needed.
Old 08-19-2010, 01:49 PM
doc Shleg's pinion flange MOVES on the pinion splines. Hopefully it is the flange and not the pinion shaft.
KD0FDS
Stephen
Old 08-19-2010, 01:59 PM
Dr. Schlegs's Avatar
Yes, Hopefully.
TLCA#5366
Old 08-19-2010, 03:34 PM
Dooh, I didn't realized there was a difference, I've been calling both micrometers. That explains a few of the puzzled looks I've gotten from Randy over the last couple of years.
If it's any consolation both of those tools can be used for the same purpose in this case since the dial caliper has both an ID and OD capabilility. The micrometer would be more precise for measuring the shim thickness but after all this is an old land cruiser where plus or minus the thickness of a credit card is probably close enough
Old 08-27-2010, 04:34 PM
John's Avatar
John John is offline
Thumbs up
OK guys,I took the easy way out . My west facing garage has been too hot for this oil orgy. I took it up to CTS in Conifer with all the "stuff" I bought for the install and let Kevin and Joe do it for a preagreed 4 hours labor. Done, and you can certainly feel it driving around but the clicking in parking lots is very soft. We will see how it performs.
Old 08-27-2010, 04:53 PM
don't freak out when you are making a turn and the thing bangs so loud yo uthink you broke an axle! Glad you got it in and going!
Old 08-27-2010, 05:06 PM
Can't go wrong with a CTS install. Nice upgrade!
Originally Posted by nakman
Old 08-27-2010, 05:28 PM
I wonder if you might notice an increase in your mpg as you learn to "light foot" the 60 around town
Old 08-27-2010, 05:58 PM
John's Avatar
Jeff- I just filled it to check that very item. The 31x10.5 I put on last week,replacing the smaller 235's, noticeably slowed down acceleration and cornering speeds, and now I will be "clutch in" coasting on more turns. This 60 gets only 12 mpg in mixed 4wd/city/hwy anyway (4 spd) so I will keep track. No autocrossing in these things!
