Notices
Old 08-20-2010, 03:09 PM
Chris's Avatar
Chris Chris is offline
Default 3FE Pro?
After failing emissions 3 times due to high NOx I'm in need of expert help in diagnosing why. The limit is 5.0 and I've gotten 7.5 the first time, 8.1 after tuning it up & today 11.2 which shows I'm moving in the wrong direction.
I did find a crack in the intake 'accordian' and thought I sealed it well but apparently not which would account for some of the increase but even when I replace that I'll probably still be high since I started out high. I'm guessing I split that when I tuned it and put it back on.
Anyone dealt with this or knows the emissions well that can find what's going on?
TIA!
Chris
Old 08-20-2010, 03:19 PM
most likely cats, How old are they chris?
http://www.risingsun4x4club.org/foru...1&postcount=13
Old 08-20-2010, 03:31 PM
Chris's Avatar
1 year old Wes, I went back to Scott at AAPerformance Muffler and they checked out fine. Working hard but as good as the day installed. Scott said my EGR tube was probably gunked up so I pulled that and it's clean. I had a flat spot on acceleration which was fixed by the tune-up and the trucks running better but the NOx is increasing.
Old 08-20-2010, 03:39 PM
I thought I remember you saying they were new.. EGR valve? is it running lean?
Old 08-20-2010, 03:55 PM
Chris's Avatar
The EGR valve appears to be working from what I can determine. Running lean? Perhaps but isn't that controlled by the EFI?
Old 08-20-2010, 04:11 PM
if you were to far advanced. what's the timing set at?
Old 08-20-2010, 04:23 PM
Chris's Avatar
I think it's right on 7 BTDC per the FSM. I have a hard time getting a line of sight on it but it should be right. Idle at 650rpm. It does idle rough but seems the nature of these motors.
Old 08-20-2010, 07:49 PM
powderpig's Avatar
Is it only NOX you are failing, can you post you other numbers as well?
How are the O 2 sensors?
If these are not working or are 80k miles down the pike, they may need to be replaced. I would only go with Denso, NTK or OEM boxed.
Old 08-20-2010, 08:20 PM
If you are sure the EGR is working, I'd check for clogged injectors. I have a spare set I've cleaned & flow tested that I can loan out if that helps.
Old 08-20-2010, 08:27 PM
Chris's Avatar
I don't know anything about both the O2 sensors or injectors. I appreciate input on how these affect NOx in particular. It's my understanding that what I'm looking for are vacuum leaks and/or EGR issues.
Latest numbers:
HC - .4027
CO - 3.77
CO2 - 668.44
NOx - 11.26
Thanks for your help.
