Old 08-21-2010, 06:54 PM
Red face My oil pressure is pinned in the "H" position
I noticed this morning that my oil pressure guage was spiked at the "H" position. Truck seems to be running fine.
I was wondering how do I check if it is the sensor and or, what could cause this.
I noticed after the 40's only run it spiked for a few minutes then went back to normal. FWIW, my fuel gauge was maxed out WAY over the "F" but I did just fill up. One more note, I did disconnect/reconnect the guages recently to restore my gauge cluster.
thanks in advance-
Drew
Old 08-21-2010, 11:19 PM
That is indicative of a short between the sender side of the gauge and ground. Do the easy stuff first. I assume it returns to the low side when the key is switched off, and pegs when the key is on, right? Probably even before the engine is running right?
Try unhooking the connector to the sender. If it is still pegged, then it is in the wiring. If it stops pegging and returns to zero, then it is a shorted sender.
Old 08-22-2010, 08:08 AM
Yep, your assumptions are dead on, thanks for the steps Jeff. Time to track it down.
