Old 08-28-2010, 10:16 AM
Beater's Avatar
Beater Beater is offline
Default head gasket on 85 22-re
so - looking at a commuter car, a 1985 celica gts convertible, that needs a head gasket. How big a job is this on a 22re? I am thinking a 3 hr job plus head mill/ck.
Thoughts?
Are all 22-re heads interchangeable? Meaning - could I put a performance re-man head on this beast?
john (johnny) henley
Old 08-28-2010, 10:30 AM
The time estimate sounds about right depending on whether you have to deal with any rusted bolts, etc. If you're replacing the head gasket I would go ahead and do a full valve job on the head and have the valve guides checked too. I would also put in a new timing chain & guide.
I'm not sure if the heads are interchangeable or not, I suspect they are but I don't know.
Old 08-28-2010, 11:20 PM
No, not all 22Rs are the same. Deck height changed 8/84 (85 model year). All 85-95 parts are interchangeable. Google '22R laser block' or poke around LC Engineering or Toysport to get the 411 on 20R and 22R lineage. And yes, all 22R-E are the same, Celica and Hilux. FWIW, I wouldn't bother with anything fancy on the head. Mine is mildly ported and polished, RV cam, oversized valves, the whole 9 yards. It's louder and uses more gas, but still slow as molasses in January. It also idles like crap. Go crazy if you are significantly increasing the compression and/or going to forced induction. On a stock bottom end and EFI, not worth it.
Old 08-29-2010, 12:39 PM
Dave, in all fairness you have a problem you've never been able to solve. My 22RE has the performance head, cam, etc and idles like butter and runs like a top. However I do agree they are still not hot rods on the street.
My suggestion was more along the lines of basic maintenance like getting the valves, valve seats, valve guides checked/rebuilt and a new timing chain.
Old 08-29-2010, 02:04 PM
My problem I'm starting think might be the AFM, which is the only part that has not been replaced, rebuilt or resoldered. It's frustrating and I grew tired of spending good time and money after bad trying to figure it out, so I just drive it, piss poor idle, weird partial throttle knock/rattle, lack of power and all. I'll put that adjustable timing gear in when I do the timing parts next spring (at 50K miles), but I've tried it on two teeth now, the one I thought and the one opposite the timing dot and it didn't make a difference. I wonder if a lobe is wrong. Being that it was delivered with no cam card or paperwork whatsoever, I've never really trusted it anyway. I've also been missing a couple of sockets for a long time, maybe those are bouncing around the crankcase. Dunno. I kept my old short block and head, so whichever gives up first gets replaced with the old parts.
100% agree, valve seats, guides, seals and new timing parts pretty much anytime you open the cover.
