Old 08-28-2010, 03:14 PM
Default Wood Stove insert.
We are getting ready to have a wood stove insert installed into an existing fireplace. Anyone have any experience with Avalon Wood Stoves. The Pendleton model is the only one we have found so far that will fit into our fireplace. Its pretty small but anything will be better than the open fireplace is now.
Old 08-28-2010, 06:01 PM
No experience with Avalon. our last Broomfield house we had one installed and my only recommendation is get one that sticks out onto the hearth, not one that's recessed all the way in the existing fireplace. It will put out more heat if it can radiate both in the front and on top, if it's just in the front you'll have the fan on a lot. At least that was my experience, hth...
Old 08-28-2010, 08:20 PM
this one will stick out and have the blower option
Old 08-28-2010, 08:59 PM
RockRunner's Avatar
No exp. with your model but you eill notice such a difference, you'll love it. Ours heats nearly 2500 sq' and that is with pine.
Thanks T aka Tom KR0MPS
TLCA #6136
Old 08-29-2010, 08:46 AM
I need a big difference. I'm tired of buying 300+ gallons of propane per month to heat the house.
Old 08-29-2010, 11:29 AM
RockRunner's Avatar
Holly cow Have you had Excel come out and do a leak test? It is a great thing to do. We found leaks that we never even thought would be there.
If they offer it I would do it ASAP.
Good for you to switching to wood.
TLCA #6136
Old 08-29-2010, 12:33 PM
Unless you have an endless supply of free firewood I would recommend getting a pellet stove insert instead.
We have the Winslow pellet stove, it's our 3rd one (3 different houses) and they work great and last forever.
Our house is 3,000+ sq ft and we heat the entire house, all winter long using only the pellet stove. We leave the gas furnace set on 50 degrees as a backup when were gone but our gas bill runs around $50 per month in the dead of winter. Keeping in mind we have a gas cooking stove and gas water heater, thats pretty good.
The Winslow stove will burn 1 40 lb bag of pellets per 24 hours at the heat level we run it on. It works just like your furnace where it lights itself and turns itself off depending on heat requirements. I can go 7-10 days and then I use a shop vac to vacuum out the ash.
I buy 5 tons of pellets from Home Depot every year in Sept, that costs around $1,000. I start burning them as soon as it's cold enough to want heat at night and they will last me until the 1st of May.
The other nice thing is they are near zero pollution especially compared to a wood stove. The burn so hot and clean they are the only type of stove you can get a permit for these days in most of the major metro areas.
Old 08-29-2010, 12:59 PM
I can get national forest fire wood permits at $10 per cord. Its a lot of work but I kind of enjoy it. Plus I've got a few more cords of standing dead on the property when even I want it. Call it emergency wood
I might be off a little on my consumption in gallons, I just did not want to post the dollar amount. We ave a 500 gallon tank that is regularly 1/2 empty or more per month in the winter. I could look into a leak but I'm not loosing it all summer. So I doubt that is my problem. 3265 square feet worth of house, with 9'/10'/24' ceilings depending on the room. Crappy windows. Can't comment on the insulation as I did not build the place. But I'm sure its nothing special.
I'll be happy if this wood stove cuts my propane bill in half. Any more will be even better.
Old 08-29-2010, 03:12 PM
We put in a Jotul 550 Rockland insert last year. Tons better than just the regular fireplace, but it didn't put much of a dent in our natural gas heating bill. Maybe 30% savings.
I agree with Tim regarding getting an insert that sticks out further onto the hearth. Ours is flush and it doesn't put out nearly the same amount of heat as a freestanding unit and the blower needs to run while burning to circulate the heat. I recall Tim had a freestanding Quadrafire at his place in Evergreen and that thing seemed to crank the heat in comparison.
This week we're upgrading our 40 year old gas boiler to a higher efficiency model and getting some of the radiator lines in the house modified. Hopefully this will help decrease our winter gas consumption. We had a few $400+ bills the last three winters we've been here and we never turn the heat up past 65.
Old 08-29-2010, 03:54 PM
We're similar, although not nearly as cold here in town as you guys. Our heating bills can be $200 per month and we have a thermostat that goes up and down, 63 at night, 67 during morning & evening (the minimum to keep our second bathroom pipes from freezing). However, we put a pellet stove insert in our fireplace last fall and it actually did help our heating bills, around 20%, or roughly 10~15% after figuring in pellets. The electricity to run the fan didn't seem to make much dent in that bill.
