Old 08-30-2010, 04:29 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Default genuine gear's ?
Anyone ever used them ? Ive never herd of them untill today. I found a guy selling a set of new 5.29 gears and install kits for both axles. He claims to have gotten them from 4wheel parts. Locally. Ive never herd on anyone in the yoda world using them. Thoughts !!
TLCA # 20314
Step by Step Bed Bob
Old 08-30-2010, 11:59 PM
All I know about them is that they are often called "Genu-whine" gears....
Just what I've read on the interweb
Old 08-31-2010, 02:25 AM
TIMZTOY's Avatar
kewl thanks
TLCA # 20314
Old 08-31-2010, 10:09 AM
Despite a really careful setup (or 2), my V6 8 inch standard rotation 5.29 genuine gears were loud for 7,000 miles. Then I ran Billings Canyon in Grand Junction. That must have REALLY loaded them up because they have been quiet since then. (what like 5 years ago now?)
The machining on the teeth is not as fine as on "better" gears which is probably the cause for the noisy gears. They were well within Toyota spec for variation in backlash when all was done.
Other than the noise early on, I haven't had any trouble with my Gen-you-whine 5.29s running dual transfer cases and 37s.
KD0FDS
Stephen
Old 08-31-2010, 11:51 AM
Trail Gear is good quality and inexpensive. They set up quite nicely.
KDěRCH
Old 08-31-2010, 04:39 PM
TIMZTOY's Avatar
thanks.. i actually want the youkon's but this guy has a whole set for about 150 less than youkons..
TLCA # 20314
Old 08-31-2010, 04:46 PM
I set up a set of Yukon "economy" series gears and recall that they had the same markings as the genuines. just a different box sometimes.
KD0FDS
Stephen
Old 09-01-2010, 01:02 AM
TIMZTOY's Avatar
Hmmmmm
TLCA # 20314
Old 09-01-2010, 03:34 PM
AddictedOffroad's Avatar
AddictedOffroad AddictedOffroad is offline
TG gears are Yukon gears. They are cut at Yukon's facility in Korea. Genuine Gear is also now cut by Yukon in Korea, but its their economy based gear now. They are not intended for use on quiet running vehicles. The TG version is a YG without the YG stamp on it. The part numbers are identical otherwise.
I have set up at least 100 TG gears without a single failure or issue to date. Setup is critical on any set. Personally, considering that the TG gears are $135/ea, I would go that route.
Uncle Ben: FWIW Chris Geiger hasn't worked for TG for well over a year.
Scotty
Old 09-01-2010, 04:19 PM
TIMZTOY's Avatar
Thanks. I guess ill go with TG's whats your thoughts on the Trail gear set up kit ?
TLCA # 20314
