Old 09-21-2010, 08:12 AM
ttubb's Avatar
ttubb ttubb is offline
I never touched the bolt on the back of the intake manifold. As long as you can cut the old rubber off, the new rubber slips on with a little soap.
X2 on the bolt for my 80 and the soap trick. You are almost there! T
KA7TLT - TLCA 13015
Old 09-30-2010, 02:01 PM
Thanks Treeroot and Terry, my dad cut the hose, worked it off, it sounds like he bent the pipe just a bit, and got it back together with fancy blue silicone hoses! No leaks yet...
He said it fought him the whole way.
Thanks all. :
Old 09-30-2010, 06:33 PM
A little late to the party but from what I read on MUD a 12mm flex head ratcheting box wrench is the trick for the bolt on the back.
I never tried mine out as I paid my mechanic to do the PHH when I originally got the truck. Blue hose should insure I never have to go there again
Old 09-30-2010, 07:10 PM
my dad tried a flex head ratchet with no luck. A flex head ratcheting box wrench would probably be able to make it work.
