Old 09-19-2010, 06:43 AM
Bighead's Avatar
Bighead Bighead is offline
Default Optima battery hissing/venting
I have a 1.5 year old Optima Red Top (34R) in my 4Runner and noticed a hissing sound coming from it after driving it home on Friday.
The 4Runner had been sitting in airport long-term parking for 5-days. I drove it home Friday and when I parked it, noticed a hissing sound coming from the engine bay. After checking it appeared to be coming from the vent nearest the positive terminal.
Is there something I should be concerned about or is this normal and I have just never noticed it before?
Thanks for the help.
Lance
2004 Land Cruiser -- OME/Slee Suspension | F/R ARB Lockers | 285/75-16 Nitto Terra Grappler | Slee Armor front, rear, sides and belly | Dual Battery | ARB Drawers
2015 4Runner Trail Edition Premium - Stock
2014 BMW R1200GS Adventure
Old 09-19-2010, 10:34 AM
is it really the battery? Pretty common to hear a hissing from the charcoal canister.. which is near the battery obviously.
Old 09-19-2010, 01:27 PM
AShoe AShoe is offline
Does it stink? Check the voltage across the battery while the truck is running. Venting gas can be a sign of overcharging. A strong sulfur smell is a sure sign of overcharging.
Old 09-19-2010, 04:30 PM
Bighead's Avatar
In the 4Runner it could be the brake accumulator but that is more of a buzzing sound and is closer to the back of the engine bay. I put my ear fairly close to the battery and the sound appeared to be coming from that positive-side vent.
Didn't notice a smell and didn't notice anything visually (any kind of colored smoke). I don't have a voltage meter because I am an electrical idiot .
Worst case, if the battery is indeed overcharging, is it safe to hook the battery back up and run it to check the voltage? Am I correct in assuming that an overcharged battery will mean I need to plan on a new primary battery this week.
Lance
Old 09-20-2010, 01:32 AM
Lance,
My old Red Top in the 40 started making the same noise when I would charge it. Not long after that it wouldn't take a charge anymore. I've written off Optimas (at least Red Tops)...I've had 3 in my 40s and none have lasted more than 2-3 years. Granted, I'm pretty hard on them as the rig isn't run much so they sit idle alot.
Old 09-20-2010, 06:00 AM
Bighead's Avatar
Lance,
Thanks Jeff. I figured the battery was probably on its way out based on what I have read here and other sites. I have had an Odyssey PC1500 sitting in my garage for the past 6-months for a dual battery set-up...time to figure out a hold-down setup and use that as the new primary in the 4Runner. Hopefully Christo has one of the Odyssey-specific chargers on the shelf...I'm sure it needs a charge.
Lance
Old 09-22-2010, 04:57 PM
TonkaToy's Avatar
TonkaToy TonkaToy is offline
We had one of these red tops do this on top of Kingston Peak and left us stranded up there until we could get down to Idaho Springs and get a new one from CarQuest. The guy there said they have had a lot of these go bad lately and trying to warranty them is useless as they are no longer around.
Old 09-22-2010, 05:01 PM
Much like Jeff, I only got 2-3 years out of my redtop optimas in the 1990s too. Stopped takin' a charge.
Back to good old lead acid. I abuse the crap out of mine winching, and they boil, and spill and sit totally dead in a frozen storage lot for a few weeks...and they keep on working for about 5 years.
KD0FDS
Stephen
Old 09-22-2010, 05:27 PM
Bighead's Avatar
I'm taking the 4Runner to a trusted shop tomorrow to get the alternator checked.
I'm wondering if I can still use the battery that vented for the drive down if it is still holding a charge. If not, I'll need to pull one of the batteries from the 100 to get down to the Springs.
Ben at Slee said my Odyssey PC1500 still had 95% charge when they checked it for me on Monday. Not bad for sitting in my garage for 6-months.
Lance
Old 09-22-2010, 05:30 PM
Originally Posted by TonkaToy View Post
...trying to warranty them is useless as they are no longer around.
Optima is no longer around? They still have a website.
