Old 10-05-2010, 01:18 PM
Boulder Cruiser's Avatar
Boulder Cruiser Boulder Cruiser is offline
Default What is this and why is it leaking
I just washed the undercarriage to try and figure out some of these leaks. I thought that this leak was coming from the oil pump or crank but i think its coming from this thing. In the pics it looks like it's coming from above that buts its dry up there. Is there an o-ring that needs replacing? After cleaning it and driving it it seems like it got worse it actually dripped on the front diff a bit. Its a 97 80.
Old 10-05-2010, 01:43 PM
Crank position sensor. Drain the oil, replace the o-ring, reinstall.
Old 10-05-2010, 01:56 PM
Just called Toyota and they dont show an o-ring separate you have to buy the whole thing to the tune of $160 Do you have a part number? Maybe i can just take it out and go find one at Mcguckin's
Old 10-05-2010, 02:08 PM
coax's Avatar
coax coax is offline
I haven't replaced that gasket yet, though it is leaking on my cruiser. Maybe some black fipg from toyota would do the trick? 10 bucks is much cheaper than a whole new sensor and much less hassle (potentially) than trying to find an appropriate seal that is oil-safe.
-Corey
'74 project pig (sold)
Old 10-05-2010, 02:21 PM
You can definately find one at NAPA or Carquest or....... You might just be able to take it out and clean it and the o-ring might still be soft.
Old 10-05-2010, 02:40 PM
I've found on my truck that FIPG actually is the Toyota-recommended seal more than a few times.
Old 10-05-2010, 03:12 PM
sleeoffroad's Avatar
The O-ring is not standard. It is a O-ring with a flange, like this O- I have tried in the past to seal with fipg but it did not work. Have never been able to locate that O-ring aftermarket.
Christo Slee
KSLE
www.sleeoffroad.com
Old 10-05-2010, 04:14 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Sounds like a job for http://www.rocketseals.com/
Old 10-08-2010, 02:22 PM
I have used Rocket Seals many times, but that was always OEM quantities - not sure if they will sell one at a time retail to the public.
Old 10-08-2010, 02:35 PM
Yup, they have a walk-up counter even.
