Old 10-10-2010, 10:48 AM
PhatFJ PhatFJ is offline
Default Ford Shock Towers
Can someone please tell me what year's I can look for at a pick and pull yard. I want to install some Ford shock towers in my 1970 fj40..
Thanks in advance for the help!!
Brian
KD0GEG
Old 10-10-2010, 11:09 AM
DanS's Avatar
DanS DanS is offline
I'm 99% sure it was from an '85 F-250.
Either way, it's part number E5TZ-18183-A and they are like $8 new. Seriously, the U-pull in Albuquerque wanted $10 for one.
Even I wouldn't go the junkyard route for $8.
Dan
Old 10-10-2010, 11:46 AM
WOW, Thanks Dan!! I had no idea they would be that cheap new. I will check it out...
Brian
KD0GEG
Old 10-10-2010, 12:47 PM
dig around on Mud or simply google ford shock towers, there are tons of threads on using them not only on toyota forums.... They are available cheap new from the right places. I paid more for mine second hand (but new) than they are available from dealers.
Old 10-10-2010, 12:57 PM
DanS's Avatar
Brian
No problem. I personally wasted a day at the junkyard to find out that they were so cheap new. Glad to save anyone the trouble.
You can see why they are so cheap though.
That's right: new ones have wavy metal on them. I'm sure they are plenty strong, but the engineer in me cringes to see new parts that aren't straight...
Dan
Old 10-10-2010, 01:06 PM
74fj40's Avatar
74fj40 74fj40 is offline
I've got a pair that have already been cut and welded.
$20 takes em!
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
Old 10-10-2010, 01:53 PM
and for that matter you could take mine too.. i won't be needing them. I also have the lower shock mounts that weld to the axle tube.
