Old 10-21-2010, 09:12 PM
Default Separating Electrical Connector
Can't see how to separate this one. Little help?
Paul McCumber - Longmont, CO
1995 FZJ80 -- 2013 Mini Cooper S Hardtop - 2013 Toyota Prius
"It's a 1970 Firebird, the car I've always wanted and now I have it. I Rule!" Lester Burnham - American Beauty
Old 10-21-2010, 09:17 PM
gahi's Avatar
gahi gahi is offline
maybe flex the blue up, insert a small flathead under the raised area.
Gary
1996 FZJ80
2000 UZJ100
Old 10-21-2010, 09:21 PM
I have a pretty small flathead but it is too wide for that. But I'm about to look for something else. The best look I got of it is when I took this picture.
Old 10-21-2010, 09:46 PM
gahi's Avatar
try from the side, all you have to do is get past the tab on the clear piece. dont go too far though.
Gary
1996 FZJ80
2000 UZJ100
Old 10-21-2010, 10:14 PM
I lifted it up from the side. That picture may look big but I didn't see a way in from the top. The side way seemed wrong but it popped out.
Old 10-22-2010, 08:29 AM
RockRunner's Avatar
Can you push the clear section down so it passes under the lifted blue section.
Thanks T aka Tom KR0MPS
TLCA #6136
Old 10-23-2010, 12:41 AM
BreckBJ44's Avatar
BreckBJ44 BreckBJ44 is offline
I belive the clear piece at the back (wire side) of the clear connection needs to be squeezed in to bring the clear block inside of the blue keyhole. You might try using a pair of fine tipped welding clamps to squeeze the pieces in...
When I dismantled the 60, I had to deal with this a few times. IIRC the key is to squeeze the clear piece hard and not to pry up the blue parts.
Kraig Hamady - Encinitas CA
1981 HJZ(BJ)44 RHD - Linked, 1999 100, ready to be built up, 1972 HZJ40 - Work in progress
Old 10-24-2010, 11:31 AM
74fj40's Avatar
74fj40 74fj40 is offline
Side Cutters?
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
Old 10-25-2010, 08:24 AM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Correct !
TLCA # 20314
Step by Step Bed Bob
Old 10-25-2010, 10:33 AM
gahi's Avatar
looks to me like he tried pushing down on the clear tab, notice the damage to it. so I was figuring that maybe the clear part is a solid piece. It looks like the blue is designed to flex.
Gary
1996 FZJ80
2000 UZJ100
