Old 11-01-2010, 04:17 PM
CardinalFJ60's Avatar
Default FJ40 gauge cluster - clustered?
So...I finally got around to putting in the new(used) guages and putting the cluster back together. I was careful to tape up the Ammeter posts so I wouldn't re-fry it. BUT...upon connecting everything and just placing it back in the dash, I touched the circuit board to the metal and it started sparking (!) Now the instrument lights are always on, but turn off when I hit the headlights, and one blinker indicator is always on. I can see where I fried the board. guages seem to all work. that's the carnage.
Here are my questions:
Is that whole circuit board live when connected? I can't imagine it is. If not, then something else must be going on.(?)
What's my next step? get a new printed board?
Old 11-02-2010, 10:33 AM
Yes, there is unswitched power available - for example, on a 40 you can turn the headlights on without the ignition key turned on. This illuminates the cluster lamps too.
Whenever working with the cluster on a 40, it is VERY IMPORTANT to disconnect the negative terminal at the battery!
Old 11-02-2010, 11:33 AM
Bummer - bitten twice. I still haven't mustered up the energy to replace my ammeter since I zapped it a couple years ago.
Old 11-02-2010, 11:50 AM
Default Totally.
twice bitten...thrice shy. I guess I just couldn't imagine the whole back panel would be 'live'. I'll get some replace parts and try again. (sigh)
Old 11-02-2010, 11:54 AM
You guys are gonna learn the hard way! Please, take Jeff's advice and pull the negative battery cable before working on electronics!
Old 11-02-2010, 11:59 AM
I've learned that procrastinating cures all problems.
Old 11-02-2010, 12:09 PM
Old 11-02-2010, 01:07 PM
why not pull the positive?
Old 11-02-2010, 01:53 PM
What do you normally use to loosen a battery terminal?
What is that tool made of?
What can happen if it slips and touches anything conductive?
Hint:
Old 11-02-2010, 03:51 PM
Hint:
True dat but one thing to keep in mind (probably not an issue on a 40): Many of the newer rigs have capacitors built into various electronics. Keeping the positive cable on will allow those capacitors to charge and touching a circuit to ground will still let them discharge even with the battery disconnected.
