Old 11-01-2010, 08:23 PM
satchel's Avatar
satchel satchel is offline
Default Bad Steering
I need the collective help here to solve my steering issues.
I've done a lot of upgrades to my truck recently, including the 5.3 motor swap and 3 inch OME lift. After all this work it would want to steer slightly to the left when I accelerate and come back to the right when letting off the gas pedal.
Marco and I threw in an aussie locker and 4.11 diff in the rear this weekend and now I have a vibration when letting off the power from the diff that I didn't have with my 3.73 diff, and the worst part is that my truck flies to the left hard when I accelerate now. It magnified the previous steering problem by at least 10.
My caster angle is set at around 3+ degrees, so I can't figure out what could be the problem. One of my thoughts is that when placing the tcase into the truck and welding it in, that the tcase pinion may be left or right in relation to the frame from where the diff pinion is making it somewhat of a diagonal angle to the diff. If it is I can't see it, but I'm thinking that under power it may be trying to pull the rear diff left or right thus making the whole rear axle housing move diagonal and make the rear want to drive off to the right or left a little. Almost like driving in crab mode if you know what that means.
Any thoughts on what it could be or things to try would be helpful.
Old 11-01-2010, 08:26 PM
satchel's Avatar
Also, I've changed out pretty much everything on the front end, all new TRE's and bushings and such, and did an axle rebuild.
Old 11-01-2010, 09:16 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
my guess... axle wrap !!! "caused by springs that are too soft fo the amount of power going to the ground " get a anti wrap bar, it should fix just about all of your issues
TLCA # 20314
Step by Step Bed Bob
Old 11-01-2010, 09:37 PM
satchel's Avatar
I'm thinking along those lines as well but 2 things are keeping me from thinking it is axle wrap or any other movement in the rear axle. First, Marco has the same setup and his doesn't do what mine is. Second, I don't understand why it would become worse with the locker. At the same time, all I changed was the locker so that pretty much means it's got to be something in the rear doing it, it certainly made it worse anyway.
Old 11-02-2010, 08:49 AM
Have you checked your toe-in on your alignment? Maybe that's not set properly...
Old 11-02-2010, 09:13 AM
TIMZTOY's Avatar
Defentlly axle wrap because with out a locker your only sending power to one wheel. With a locker it's both. And juat because he has the "same set up" he does have a different right foot and a diffrent frame. Stress spots & week spots between frames. Also problly has diffrent tires as well. Resulting I. Different contact patch in the tires and grip caracteristics.
TLCA # 20314
Old 11-02-2010, 09:58 AM
satchel's Avatar
Yes, I checked the toe in and all is good there. Might look into an anti wrap bar. Thanks for the suggestions.
Old 11-02-2010, 10:08 AM
Just to clarify... this is on a 60?
Old 11-02-2010, 10:12 AM
Aussie lockers only power one wheel initially at least. Also, I am not too sure it is axle wrap since they are OME Heavies and the truck is sprung under. Those springs are pretty stiff.
Old 11-02-2010, 10:53 AM
It might be worth having an alignment shop measure it to see how square the rear axle is to the front axle. The number you're looking for is the thrust angle. Ask the shop if they measure that angle before having them do the work.
http://www.familycar.com/Alignment.htm
