Old 11-03-2010, 03:54 PM
Default Where to find hardware like this?
I'm building something and I need a piece of hardware that I'm not sure exists.
Something like this (sorry for the crappy illustration):
Basically I have a length of 5/8" threaded rod that I want to anchor into a beam. I need a cylindrical piece of rod, 3" long that is drilled and tapped to accept the rod. Is there anything off the shelf that I can get that will do this? Or will I have to make something? Any other ideas?
Thanks for letting me pick your brains.
Old 11-03-2010, 04:12 PM
Search mcmaster.com and see what you can find.
Old 11-03-2010, 04:33 PM
coax's Avatar
coax coax is offline
So I am bored and it appears its called something like a cross dowel nut or barrel nut, though I can't find them on mcmaster
-Corey
'74 project pig (sold)
Old 11-03-2010, 04:38 PM
Damn. One man's crappy illustration is another man's masterpiece.
Originally Posted by nakman
Old 11-03-2010, 04:39 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Make it your self. Hell it would only take like 5 minutes to make it. I have everything but the 3" piece. But you can pick it up At depot.
But I suppose it all depends on how much they want for it when you find it
TLCA # 20314
Step by Step Bed Bob
Old 11-03-2010, 04:48 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Basically I have a length of 5/8" threaded rod that I want to anchor into a beam. .... Any other ideas?
This does sound like something where fabrication is the easiest solution easily made, but what is the application. Maybe there is a different solution. Pick my homebuilder brain.
I have seen similar setups of smaller diameter components frequently used for furniture that one assembles at home.
What diameter of 3" smooth rod do you need? Why is the anchor a rod vs. a plate or a threaded insert? (pictured below) What is the load?
Old 11-03-2010, 04:51 PM
TIMZTOY's Avatar
True. I could easily just drill a hole and weld a nut on the back of the plate and that would take less time than threading a hole.
So 2 minutes. Lol
TLCA # 20314
Old 11-03-2010, 05:09 PM
Yeah, if I had the tools, it would be the easiest solution, but I don't.
The application is basically needing to anchor a 5/8 piece of threaded rod into a 3" thick softwood beam so that it can hold weight. I would use a lag, but I don't trust the wood. So, I'm thinking that the drilled/tapped metal rod passing through the beam would help secure the threaded rod. I can't use a plate because there's no clean way to pass it through the beam, and it can't be placed on the top/side becasue of the location. (not sure if that makes sense).
Old 11-03-2010, 05:18 PM
Those seem close. I just need a really big one! I'll start searching. thanks.
Old 11-03-2010, 05:28 PM
TIMZTOY's Avatar
So it has to go threw the 3" piece regardless ?
Buy some rod and bring your threaded rod to the meeting and I'll drill and tap it for you. As Many as needed.
TLCA # 20314
