Old 11-08-2010, 12:31 PM
I'm afraid to beat on it too hard with a chisel/punch and risk knocking off the captured nut. Not sure what I'd do if that happened......
Marco - probably about 1/8" recessed.
Old 11-08-2010, 01:09 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Grind it smooth with the frame. Weld on a bolt to the frame facing down And bolt your bump stop to the new welded bolts. Id also reccomed using a larger bolt and re drill the bump stop to accommodate the bigger studs day 10 or 12'm shaft. IF you juat must get it out. Best Way is to take a chizzle and lightly tap the extractor clockwise It should relase it's grip and just fall out.
TLCA # 20314
Step by Step Bed Bob
Old 11-09-2010, 12:55 PM
or we could torch it out pretty easily...
That's exactly what I did. On the same two bolts. For the same reason.
EZ-outs (extractors) are made of the same hardened carbon steel that drill bits are made of.
If it isn't too rusty, you might have some luck with a small (~1/4 wide) cold chisel. Mine were too rusty for that. After I torched them out, I redrilled and tapped and helicoiled.
After that fiasco I decided not not use EZ-outs any more
Old 11-09-2010, 02:15 PM
That's exactly where I am at this point - bolt extractors are evil. For the 3 other bolts I snapped yesterday, i just drilled out the remains of the bolt and than ran a tap to clean out what was left.
Old 11-10-2010, 06:21 PM
to the torch. It made quick work of those bolt remnants.
Old 11-10-2010, 08:48 PM
Yeppers, that's what I did. And banish those evil extractors to the scrap heap!
