Old 11-13-2010, 08:38 AM
Unhappy Cracked Block
I've been loosing coolant and recently it has gotten worse. I was a bit dumfounded as I could not see where the coolant was leaking from any of the hose connections, radiator, my oil was clean and my exhaust appeared to be clean. I did notice some staining under the water pump and so I replaced it on Monday evening. While doing so, I replaced my water pump mounting bolts. The coolant leak was still there. Yesterday evening, I found the source of my leak, several cracks on the engine block.
The telltale stains have been there since shortly after I installed the engine. I had wondered from time to time where they were coming from, now I don't have to wonder any more.
Old 11-13-2010, 08:56 AM
That sucks man, especially after all the work you've done to get your 40 running strong. Where did you source that engine from?
Old 11-13-2010, 09:01 AM
bummer
Old 11-13-2010, 09:10 AM
He got it from me, after I got it from someone else. If I had only known......Little bugger ran good too and it was balanced and blue printed.
Well make it right though, I've got the 1.5F block that came out of my 74. We'll bore that out to match the pistons in Ricardo's engine and swap the balanced assembly over and he'll be good to go.
Old 11-13-2010, 09:33 AM
Dr. Schlegs's Avatar
Your an upstanding man Randy!!!!! Ricardo sorry to hear that your hard work was for not.
TLCA#5366
Old 11-13-2010, 09:38 AM
Sorry to hear about that Ricardo
Old 11-13-2010, 09:50 AM
That block was cracked back in the 80's when I owned it. I had a guy who specialized in welding cast iron come in from out of town to try his best to repair the crack. As he welded the original crack with nickel rod he'd peen the surrounding area to try to keep it from cracking again as it cooled. Japanese cast being what it is, there was no joy, it just kept cracking.
I repaired the cracks I found by grinding them out and filling them in with JB Weld because I didn't want to pull the engine out again. It did seem to hold for all these years, but the engine probably had no more than 20 miles on it. It seems there are still some hairline cracks that have opened up. I wouldn't have reinstalled it without swaping the guts into a new block, but that's water over the dam now. You might want to try doing what I did back in the eighties and just grind the cracks out and JB Weld them. It did hold a pressure test back then after the first repair.
Old 11-13-2010, 10:01 AM
waggoner5's Avatar
You can clearly see the repairs in Ricardos pics. Best of luck on the swap Ricardo. Bummer.
Old 11-13-2010, 10:22 AM
treerootCO's Avatar
Event Coordinator
I have two 2F builders if you need a new block. Free to a good home .
My North engine is - 441050 = Mar '80
My South engine is - 334175 = Dec '78
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 11-13-2010, 10:33 AM
I've been trying to source another 2F block for ages, can I call dibs on one in trade for a case of your favorite cash, whatever?
